| New Reply |
Unbounded operators in non-relativistic QM of one spin-0 particle |
Share Thread | Thread Tools |
| Apr6-09, 07:12 AM | #18 |
Mentor
This is a very interesting thread in which I would like to participate actively, and from which I would like to learn, but I'm too busy with work for the next week or two to do the necessary reading and thinking.
This is an example of something much more general. If two self-adjoint operators satisfy a canonical commutation relation, then it is easy to show that at least one of the operators must be unbounded. "We must emphasize that we regard the spectral theorem as sufficient for any argument where a nonrigorous approach might rely on Dirac notation; thus, we only recommend the abstract rigged space approach to readers with a strong emotional attachment to the Dirac formalism." I also think that the reason for the popularity of the Hilbert space approach is historical. In the early 1930s, before the work of Schwartz and Gelfand on distributions and Gelfand triples, von Neumann came up a rigorous Hilbert space formalism for quantum theory. I think if a rigorous rigged Hilbert space version of quantum theory had come along before the rigorous Hilbert space version of quantum theory, then the Hilbert space version might today be even less well-known than the rigged Hilbert space version actually is. Students would now be hearing vague mutterings about "making things rigourous with Gelfand triples," instead of hearing vague mutterings about "making things rigourous with Hilbert spaces." |
| Apr6-09, 03:21 PM | #19 |
In my understanding, the reason why standard Hilbert space formalism is not suitable for QM is rather simple. Let's say I want to define an eigenfunction of the momentum operator. In the position space such an eigenfunction has the form (I work in 1D for simplicity)
[tex]\psi(x) = N \exp(ipx)[/tex] where [tex]N [/tex] is a normalization factor. This wavefunction must be normalized to unity, which gives [tex] 1 =\int \limits_V |\psi(x)|^2 dx = N^2V[/tex] where [tex]V[/tex] is the "volume of space", which is, of course, infinite. This means that the normalization factor is virtually zero [tex] N = 1/\sqrt{V}[/tex] So, the value of the wavefunction at each space point is virtually zero too, and it can't belong to the Hilbert space. But the wavefunction is not EXACTLY zero, because its normalization integral is equal to 1. So, here we are dealing with resolving uncertain expressions like "zero x infinity". As far as I know, there is a branch of mathematics called "non-standard analysis", which tries to assign a definite meaning to such "virtually zero" or "virtually infinite" quantities and to define mathematical operations with them. I guess that using methods of non-standard analysis in quantum mechanics could be an alternative solution for the "improper states" in QM (instead of the rigged Hilbert space formalism). Did anyone hear about applying non-standard analysis to QM? |
| Apr6-09, 06:40 PM | #20 |
Mentor
I'm still a bit confused by distributions and tempered distributions. Let's see if we can sort this out.
We define D to be the set of all [itex]C^\infty[/itex] functions from [itex]\mathbb R^n[/itex] to [itex]\mathbb C[/itex] with compact support. (This D isn't used in the construction of a rigged Hilbert space. I'm defining it just for completeness). We say that [itex]\phi_n\rightarrow\phi[/itex] if there's a compact set K that contains the supports of all the [itex]\phi_n[/itex], and every [itex]D^\alpha\phi_n[/itex] converges uniformly on [itex]\mathbb R^n[/itex] to [itex]D^\alpha\phi[/itex]. Here we're using the notation [tex]|\alpha|=\alpha_1+\cdots+\alpha_n[/tex] [tex]D^\alpha f(x)=\frac{\partial^{|\alpha|}}{\partial x_1^{\alpha_1}\cdots\partial x_n^{\alpha_n}}f(x)[/tex] The members of D are called test functions. Now we define a distribution as a linear function [itex]T:D\rightarrow\mathbb C[/itex], which is continuous in the following sense: [tex]\lim_{n\rightarrow\infty}T(\phi_n)=T(\lim_{n\rightarrow\infty}\phi_n)[/tex] I think I would prefer to do it a bit differently (if the following is in fact equivalent to the above, but it might not be). We define an inner product and the associated norm by [tex]\langle f,g\rangle=\int_D f g\ d\mu[/tex] where [itex]\mu[/itex] is the Lebesgue measure on [itex]\mathbb R^n[/itex]. Now we define the space of distributions to be the dual space of D. Is this definition equivalent to the first? |
| Apr6-09, 06:41 PM | #21 |
Mentor
Now let's consider tempered distributions. We define S as the set of all [itex]C^\infty[/itex] functions from [itex]\mathbb R^n[/itex] to [itex]\mathbb C[/itex] that satisfy
[tex]\sup_x\{|x^\alpha D^\beta\phi(x)|}<\infty[/tex] for all [itex]\alpha[/itex] and [itex]\beta[/itex]. I'm using the notation [tex]x^\alpha=x_1^{\alpha_1}\cdots x_n^{\alpha_n}[/tex] The set S is called the Schwarz class (at least by Folland). Now, I would like to say that a member of its dual space is called a tempered distribution, but that doesn't seem to be how it's done. Instead of using the standard norm, we define an infinite number of new norms: [tex]\|\phi\|_{r,s}=\sum_{\alpha\leq r}\sum_{\beta\leq s}\sup_x\{x^\alpha D^\beta \phi(x)\}[/tex] and define a tempered distribution as a linear functional that's bounded with respect to at least one of these norms. I'm pretty confused by this. Is the set of tempered distributions the dual space of the Schwarz class or not? |
| Apr6-09, 06:44 PM | #22 |
Recognitions:
in terms of "projection-valued measures" to which Lebesgue integration theory is applicable. |
| Apr6-09, 06:54 PM | #23 |
Mentor
| Apr6-09, 07:03 PM | #24 |
Mentor
We now have two mathemathcally sound solutions to the problem that a self-adjoint operator need not possess a complete set of eigenvectors in the Hilbert space of vectors with finite norms. The first, based on the spectral theorem (Theorem 4 of Sec. 1.3), is to restate our equations in terms of projection operators which are well defined in Hilbert space, even if they cannot be expressed as sums of outer products of eigenvectors in Hilberbert space. The second, based on the generalized spectral theorem, is to enlarge our mathematical framework from Hilbert space to rigged Hilbert space, in which a complete set of eigenvectors (of possibly infinite norm) is guaranteed to exist. |
| Apr6-09, 07:26 PM | #25 |
Mentor
| Apr7-09, 01:05 AM | #26 |
Recognitions:
to be what your 2nd defn is (by default), and the "topological dual" which corresponds to your 1st defn. The linear functionals in the topological dual space are required to be continuous. Therefore, the topological dual is (in general) a subspace of the algebraic dual (since there's an extra restriction is imposed upon the former). FAPP, you might as well just concentrate on the topological dual. (I'll respond to the tempered distribution question in a later post.) |
| Apr7-09, 01:14 AM | #27 |
Recognitions:
space of tempered distributions is indeed the (topological) dual of the Schwartz space. This coincides with Lax (p559) and also the Wiki page http://en.wikipedia.org/wiki/Distribution_(mathematics) . See the section "Tempered distributions and Fourier transform". Warning: read the paragraph starting "The space of tempered distributions is defined ...." very carefully since the wording is a little confusing if read too quickly. |
| Apr7-09, 01:18 AM | #28 |
Recognitions:
from what Avodyne was saying (which involves a restriction to finite domains in both position and momentum space, and is thus only a subspace of the unrestricted Hilbert space that Ballentine refers to. |
| Apr7-09, 01:30 AM | #29 |
Recognitions:
The singular behaviours arising from the interaction terms in the Hamiltonian become far more pathological than mere delta distributions. Secondly, there are general theorems about how not all operators are sensible observables. There's a little more on this at the end of a previous thread: http://www.physicsforums.com/showthr...=262821&page=2 Thirdly, there are so-called Bogoliubov transformations of the a/c ops in QFT which take you from one Hilbert space into another unitarily inequivalent one. This stuff is important in condensed matter physics, and other stuff like Hawking-Unruh. Hence, plenty of people believe that it's better to start with the algebra of relevant physical observables, and then construct states as linear mappings from the algebra to C. In that formalism, issues like those above are more out in the open. |
| Apr7-09, 07:25 AM | #30 |
Mentor
So what I had in mind is the topological dual of a vector space with the topology induced by the inner product. What's confusing me is the definition of continuity. It seems natural to me to define the standard inner product, and use the concept of continuity induced by it. But instead, we choose to define convergence of a sequence in D, and use that to define continuity. These definitions may be equivalent, but it's not obvious that they are. It gets even more weird in the case of tempered distributions. We have defined an infinite number of norms, which should give us infinitely many kinds of continuity. Maybe I'm just overlooking something simple, but it seems weird that none of the texts (Wikipedia, Streater & Wightman, Folland) say anything about it. |
| Apr7-09, 07:36 AM | #31 |
Mentor
but I recognize the claim from here. Their refererence is this, but I don't really understand it. I think I understood one thing though. A self-adjoint operator is only an observable if it preserves each superselection sector. For example, it can't take a bosonic state to a fermionic state.
| Apr7-09, 06:15 PM | #32 |
Recognitions:
that talk about this in excruciating detail. It's peripheral to the main subject of the current thread, so you probably won't want to wade through 50-pages of nontrivial math. Maybe just look at p18: the paragraph starting with early sections to get the context. EDIT: A better reference might be math-ph/9809015. But like I said, this goes off on an tangent from the current thread. |
| Apr7-09, 06:32 PM | #33 |
Recognitions:
answer. Maybe you should re-summarize? a sequence of spaces, each densely nested in the previous (larger) one. So "continuity" applies in the context of the norm topology on each subspace. The tempered distribution case applies to the (dual of) the "inductive limit" of this sequence of spaces (afaiu). |
| Apr7-09, 07:45 PM | #34 |
Mentor
Option 1: Define the usual inner product. The inner product gives us a norm, and the norm gives us a metric. Now we can use the definition of continuity that applies to all metric spaces. [itex]T:\mathcal D\rightarrow\mathbb C[/itex] is continuous at [itex]g\in\mathcal D[/itex] if for each [itex]\epsilon>0[/itex] there's a [itex]\delta>0[/itex] such that [itex]\|f-g\|<\delta\implies|T(f)-T(g)|<\epsilon[/itex]. T is continous on a set [itex]U\subset\mathcal D[/itex] if it's continuous at each point in U. Alternatively, and equivalently, T is continuous on [itex]U\subset\mathcal D[/itex] if [itex]T^{-1}(E)[/itex] is open for every open [itex]E\subset\mathbb C[/itex]. Weird, it takes a lot less to cause a database error now than a couple of weeks ago. I'll continue in the next post. |
| New Reply |
| Thread Tools | |
Similar Threads for: Unbounded operators in non-relativistic QM of one spin-0 particle
| raising and lowering operators for spin | Quantum Physics | 3 | ||
| spin angular momentum operators | Advanced Physics Homework | 1 | ||
| spin angular momentum operators | Quantum Physics | 5 | ||
| spin operators | Advanced Physics Homework | 2 | ||
| Help me (Spin Operators) | Introductory Physics Homework | 6 | ||
