[(2*(n^2)+1] MUST be divisible by 3
  • Context: Undergrad
  • Thread starter Thread starter Almutairi
The discussion revolves around the divisibility of the expression [2*(n^2)+1] by 3, particularly for integers n that are not divisible by 3 and not equal to 0. Participants explore various proofs and approaches to establish or challenge this claim, engaging in mathematical reasoning and exploration of modular arithmetic.
  • One participant suggests that if n is an integer not divisible by 3, then [2*(n^2)+1] must be divisible by 3, and seeks a simpler proof.
  • Another participant presents two cases based on the value of n modulo 3, concluding that n^2 is congruent to 1 modulo 3 in both cases.
  • Several participants point out a misunderstanding regarding the expression, clarifying that it should be interpreted as 2*n^2, not 2 raised to the power of n^2.
  • One participant proposes a proof using the relationship between integers and their divisibility by 3, suggesting that if n is divisible by 3, then [2*(n^2)+1] is never a multiple of 3.
  • Another participant discusses the use of modular arithmetic to evaluate the expression, showing that [2*(n^2)+1] is congruent to 0 modulo 3 when n is not divisible by 3.
  • A later reply introduces a proof involving the integer properties of n and its implications for divisibility, leading to a contradiction that suggests either n or [2*(n^2)+1] must be a multiple of 3.
  • Participants express appreciation for insights shared about modular arithmetic and its applications in proofs.
There is no clear consensus on the proof or the validity of the initial claim. Multiple competing views and approaches are presented, with some participants agreeing on certain aspects of the modular arithmetic while others challenge the interpretations and conclusions drawn.
Some proofs presented rely on assumptions about the properties of integers and their behavior under modular arithmetic, which may not be universally accepted without further clarification. The discussion also highlights the complexity of proving divisibility in number theory.
Almutairi
Hi,
while trying to answer a home work question I came up with an unrelated equation, although it is very trivial it seemed interesting to me:
If n is an integer not divisible by 3 and not equal to 0, then [(2*(n^2)+1] MUST be divisible by 3.
I tried to proof it using the fact that
(n^3)/3 + (n^2)/2 + n/6 is always an integer. It seemed good but I stopped in the second page!
So my question is there a nicer shorter way to proof it?
Thanks
Two cases:
[tex]n \equiv 1 \mod 3 \Rightarrow n^2 \equiv 1 \mod 3[/tex]
[tex]n \equiv 2 \mod 3 \Rightarrow n^2 \equiv 1 \mod 3[/tex]
Either way, [itex]n^2 \equiv 1 \mbox{ mod } 3[/itex]. Now just plug this in...
Welcome to PF!
Hi Almutairi! Welcome to PF! :smile:
(try using the X2 tag just above the Reply box :wink:)
Sorry, but 2(22) + 1 = 16 + 1 = 17 :redface:
Generally, 22n - 1 = 4n - 1 is divisible by 3, and so is 22n+1 + 1, as you can see by writing 4 in ternary (ie, it's "11" in base3). :wink:
[tex]2\cdot n^2 \mbox{, not } 2^{n^2}[/tex]
thanx for the welcome, and sorry for the confusion:smile: but I meant 2n2, and also you used 2 as a value of n but 2 is not divisible by 3 (i.e 2/3 is not an integer). So for example
let n=7( seven is not zero and not divisible by 3)
so (72)*2=98 and 98+1=99 which is divisible by 3.
also the opposite statement can be made so together:
1) If n is an integer not divisible by 3 and not equal to 0 then [2n2+1] is Always a multiple of 3
2) if n is an integer divisible by 3 and not equal to zero then [2n2+1] is NEVER a multiple of 3.
To explain this great theorem:biggrin: you could relate it to odd and even numbers(divisible by 2 or not) the same here, you could divide integers into numbers divisible by 3 or not, however, to transform an integer from the first category to the second you (double its square and add one) instead of just adding one.
I proved it using the fact that (n3)/3 + (n2)/2 + n/6 is always an integer, but as I said it was long, I will post it later.
signerror said:
Two cases:
I am sorry I didn't understand what you were trying to do could you please explain it differently.
Write n in ternary …
if it ends in 1 or 2, then n2 ends in 1 :wink:
What if you take the 2 possible cases
[tex]n=3p+1[/tex] and [tex]n=3p+2[/tex], where 'p' is arbitrary in the set of natural numbers
You could prove it with less paper (supposedly) by using
1 = 12
1 + 3 = 22
1 + 3 + 5 = 32
1 + 3 + 5 + 7 = 42...and so forth with this pattern
Proof
Given that [(n3)/3 + (n2)/2 + n/6] is an integer, then
[ 2n3 + 3n2+ n] is an integer that is a multiple of 6
and therefore, [2n3+ n] is a multiple of 3
and it can be written as n[2n3 + 1]
so either n or [2n2 + 1] is a multiple of 3, or both.
To rollout the possibility of both being a multiple of 3 we need another proof:
Let both n and [2n2 + 1] be multiples of 3,
then 2n2 is NEVER a multiple of 3……………………...(A)
However, by a counter example we can show this is not true
(e.g. 2*32=18), so either it is sometimes true or always true. For obvious
reasons it can’t be sometimes true and sometimes not true, so
2n2 is always a multiple of 3…………………………. (B)
Statements A and B are clearly in contradiction.
so either n or [2n2 + 1] is a multiple of 3.
Almutairi said:
Proof
Great proof. You have a talent for math to have noted this. As you learn more number theory you will find the mod operator mentioned by Signerror to be a powerful tool not to be ignored. Basically as you subtract or add n to any number it stays equivalent mod n. Thus X =* X + nt mod n where X, n and t are integers. Usually we write three parallel lines like the equal sign to show equivalence but some people justuse the "=" sign where it is understood to mean equivalence and not equals. We say that a set of numbers is a complete residue system mod n whenever any integer mod n must be equivalent to one of the members of the set. Now since it is always possible to add or subtract n from any integer to get a number between and including 0 and n-1 then the set of numbers from 0 to n-1 is a complete set of residues mod n. Thus 0 through 2 is the complete set of residues mod 3. If a number is divisible by 3 then N =* 0 mod 3, otherwise N =* 1 or 2 mod 3. So we can substitue either 3t + 1 or 3t+2 for any number not divisble by 3 to evaluate an expression to see whether it is divisible by 3 is the same as evaluating whether it =* 0 mod 3. Where only addition, subtraction or multiplication are involved, we can simplified an expression mod n by adding or subtracting n as many times as appropriate. Thus 2*(3t+1)^2+1 =* 2*(3t - 3t +1)^2+1 =2* 1^2+1 =* 0 mod 3 and 2*(3t +2)^2+1 =* 2*(3t-3t-3 +2)+1 = 2*(-1)^2 +1=* 0 mod 3, Thus 2n^2 + 1 =* 0 mod 3 when ever n is not 0 mod 3.
Thank you for the confidence boost, and also thanks for the mod operator info it really helped. Unfortunately, every one who knows me will count this as a life achievement:smile:.
Unfortunately, ones ego is often set even before preschool. Because of the programing you under go in your early years one's subconscious mind often works to sabotage ones efforts to succeed. It never matters what others believe you are capable of if you yourself work subconciously to prove yourself to not have the talent. You most likely have the talent but do not know it. Your work shows that you have talent in math. If I were you, I would never base my goals purely on others or even your own concepts about your talent. If you believe in your self you will succeed in math. I can see that from what you done. My advice is to for you continue to post more of your work or questions in this forum. Give it your best, you may surprise yourself!
  • · Replies 21 ·
