| Thread Closed |
Antarctic ice shelf half the size of Scotland on verge of collapse |
Share Thread | Thread Tools |
| Apr4-09, 07:39 PM | #1 |
| Apr5-09, 10:14 AM | #2 |
Here is a video showing the Wilkins ice shelf
| Apr5-09, 07:55 PM | #3 |
http://www.antarctica.ac.uk/press/pr...ase.php?id=376
JIM ELLIOT, BRITISH ANTARCTIC SURVEY: There are about 1,500,000 km^2 of ice shelves in Antarctica. Wilken is about 16,000 km^2 of that or about the size of Connecticut or Jamaica. Good news is that when they breakup they do not contribute much to a rise in sea level. However, the rate of breakup is such that there won't be many left in another 100 years or so. The Arctic used to have ice shelves too. However, they are mostly gone now. Once ice shelves are gone, the warming begins to work on land based ice and that melting does contribute directly to a rise in sea level. No need to immediately sell ocean front property, but long term this will be an issue. http://news.bbc.co.uk/2/hi/science/nature/3132074.stm |
| Apr5-09, 08:12 PM | #4 |
An enormous amount of fresh water goes to waste. 16,000 km^2 and a thickness of 100 meters, that's about 1400 km^3 of water. People can live quite well with 100 liters per day, so this would be enough for the entire world for 6 years.
| Apr6-09, 08:07 AM | #5 |
![]() http://nsidc.org/data/seaice_index/ So then, are there other regions of the Antartic shelf that are experiencing unprecedented cooling? Or if not, is the region of warming small compared to the regions of cooling? And if that is the case, what makes this significant? |
| Apr6-09, 09:15 AM | #6 |
Recognitions:
| Apr6-09, 09:20 AM | #7 |
Gokul;
The most current peer reviewed paper on the subject has found that there is robust warming across Antactica: Sea ice comes from more than just freezing temperatures. With the breakup of such massive ice shelves, it's not too surprising that sea ice extent has trended upward. These ice shelves are initially hundred of meters thick. After they float out to sea, they eventually breakup into smaller pieces and then cover surface areas much larger than they did originally. The Arctic on the other hand has almost no ice shelves left. This is why there is never any news about them and also why sea ice extent in the North has been trending downward. However, both polar regions are warming. |
| Apr6-09, 10:16 AM | #8 |
| Apr6-09, 05:26 PM | #9 |
Do you have other ideas for how an ice cap builds up? The whole basis of deuterium temperatures obtained in paleoclimate studies from ice cores is based on the fact that an ice cap is built up by precipitation. Cheers -- Sylas |
| Apr6-09, 05:40 PM | #10 |
Recognitions:
I don't know if thse ice shelves are the result of recent local snow fall or they are ancient ice that moved in glaciers from further inland. Which would also mean the recent increase in ice coverage in the graph is irrelevant. ps. why the size of Scotland? The standard unit for size is "Wales". And at 20,000km^2 is a lot closer to the size of this event than Scotland (at 75-80,000km^2) anyway |
| Apr6-09, 07:05 PM | #11 |
| Apr6-09, 07:17 PM | #12 |
| Apr6-09, 07:45 PM | #13 |
The context of the remark, as I understand it, is from your msg #5, where you noted that there is increasing ice in the southern hemisphere. You were referring to sea ice cover; and I was thinking of the ice cap. Yes, sea ice cover doesn't have much at all to do with precipitation. The biggest variations are, of course, between summer and winter, and relate to temperature. Differences from year to year are much smaller, and there are all kinds of effects that can have an impact on this. Ocean currents are important, especially around the Antarctic. I agree with you that changes in precipitation are unlikely to be much of a factor. (Addendum added in edit: although it might. I'm reading a bit of background, and it seems that precipitation could be a factor after all.) Cheers -- Sylas |
| Apr7-09, 01:25 PM | #14 |
Here's an peer reviewed science journal article on increasing Antarctic sea ice. Although I'm not entirely comfortable with it, the suggestion is that decreasing salinity leads to a staginating ocean surface near that Antarctic. From this, less heat from the depths is available to melt the sea ice.
http://psc.apl.washington.edu/zhang/...20-11-2515.pdf |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Antarctic ice shelf half the size of Scotland on verge of collapse
| matter on it verge of zero energystare | Atomic, Solid State, Comp. Physics | 1 | ||
| Antarctic Ice Marathon | General Discussion | 4 | ||
| Scotland | History & Humanities | 11 | ||
| On verge to greatness | Calculus | 5 | ||
| The collapse of religion, mass suicides, the collapse of governments? | General Discussion | 25 | ||
