Linear algebar!!!distance between two lines,help for part(b)
by tengxiaona
Tags: algebardistance, linear, lines, partb
tengxiaona
tengxiaona is offline
#1
Apr6-09, 09:55 PM
P: 8
(a)use cross product to find the distance d from the line K determined by the two points(4,4,4) and (-1,-2,-5) to the line L determined by the parametric equations x=3,y=-1,z=5-5t
(b)find two points P and Q on the lines K and L respectively in part(a) such that the idstance from P to Q is d.
2. Relevant equations
projection formula, corss product
3. The attempt at a solution
i slove part(a)
i set A as (4,4,4) and B as (1,-2,-5), then we can get -->AB=(-3,-6,-9)
from x=3,y=-1,z=5-5t , we get C as (3,-1,-5),then -->AC=(-1,-5,1)
and we know l(distance between L and K)=area of parallelogram/length of AB
which is
l= ||-->AB*-->AC|| / ||-->AB||
now i use cross product -->AB*-->AC=(-3,-6,-9)*(-1,-5,1)=(-39,-12,21)
FINALLY i get l= sqrt(117/7)
i think i did right way for part(a)
but for part(b)
i find the projection of -->AC first
proj(AC)={AC*AB/AB*AB}AB
=(3+30-9)/126 (-3,-6,-9)
=4/21(-3,-6,-9)
ok, till here,
can i use (4,4,4)as point P
then use C(3,-1,-5) minus (4/21)(-3,-6,-9) to get point Q?
if i did wrong way ,plz give me a hand
thanks!!!
Phys.Org News Partner Science news on Phys.org
Simplicity is key to co-operative robots
Chemical vapor deposition used to grow atomic layer materials on top of each other
Earliest ancestor of land herbivores discovered
tengxiaona
#2
Apr7-09, 12:41 AM
P: 8
i get some ideas from another topic
http://www.physicsforums.com/showthread.php?t=274638
i use the eqution wut Dick offered X_p(s)-X_q(t)=u*W
then i get
(4,4,4)+t[-3,-6,-9] - (3,-1,5)+s[0,0,-5] = u[30,-15,0]<--cross product by deriction vectors
i solve it and get t=11/15 s=38/25 u=-1/25
wuts next?
PLZ HELP
tengxiaona
#3
Apr8-09, 12:06 AM
P: 8
any1 help me !! plz!!
Billy Bob
Billy Bob is offline
#4
Apr8-09, 10:15 AM
P: 394
Your original posted solution to (a) gives the dist from C to K, but how do you know C is the closest pt to K? Your original (a) is wrong because K and L don't lie in the same plane.
Look at your second post.
The skew lines K and L lie on two parallel planes P1 and P2. The distance between K and L is the distance between the two planes P1 and P2.
Your vector [30,-15,0] is perpendicular to both planes P1 and P2.
(4,4,4)+t[-3,-6,-9] when t=11/15 is pt M on line K
(3,-1,5)+s[0,0,-5] when s=38/25 is pt N on line L
Vector MN is parallel to [30,-15,0].
You are ready to write down the answer to both parts now, do you see it?
Register to reply
Related Discussions
Distance between two skew lines given by parametric equations (and more!) Calculus & Beyond Homework 2
Distance between two lines in 3D Calculus & Beyond Homework 3
Distance between two parallel lines Calculus & Beyond Homework 4
Distance between two lines Calculus & Beyond Homework 3
find the shortest distance between 2 non-paralle lines (skew lines) in 3-space Calculus 4
