| Thread Closed |
Why can't you measure the temperature of multiphase flow's? |
Share Thread | Thread Tools |
| Apr8-09, 09:20 PM | #1 |
I've read from many sources that thermocouples or any other type of thermal transducer can't accurately measure the temperature of multiphase flows but none of them explain why. For instance, a mixture of air and ethanol going through a fuel line at 80 C. Why is it that if you stick a thermocouple in the fuel line to measure temperature, it won't give you an accurate result? At 80C there shouldn't be much of an effect of radiative heat transfer and given a steady flow and temperature there should be no issues with changes in convective heat transfer. So what gives, why can't you do this?
| Thread Closed |
| Thread Tools | |
Similar Threads for: Why can't you measure the temperature of multiphase flow's?
| how to measure temperature? | General Physics | 1 | ||
| How can multimeter measure temperature? | General Physics | 1 | ||
| Refractive index to measure temperature | Introductory Physics Homework | 2 | ||
| temperature measure | Introductory Physics Homework | 0 | ||
