Calculate Voltage Across Resistor Without Voltmeter
The discussion revolves around determining the actual voltage across a 200k ohm resistor when a voltmeter with an internal resistance of 100k ohm reads 40V across it. Participants are exploring the implications of the voltmeter's internal resistance on the voltage measurement.
  • Participants suggest breaking down the voltmeter into an ideal voltmeter and its internal resistance to analyze the circuit configuration. There is also a focus on understanding what is meant by measuring voltage "across" the resistor and how this relates to the circuit setup.
Some participants are attempting to clarify the circuit diagram and its implications for the voltage readings. There is an ongoing exploration of how the voltmeter affects the overall resistance and voltage distribution in the circuit. Guidance has been offered to visualize the circuit more clearly, but no consensus has been reached yet.
There is a request for a clearer circuit diagram to facilitate understanding, as the current representation is not displaying properly. The original poster expresses uncertainty about their calculations and the meaning of measuring voltage "across" the resistor.
kyip
A voltmeter with internal resistance of 100k ohm reads 40V across the 200k ohm resistor of the circuit. Determine the actual voltage across the resistor( without the voltmeter)
my anawer:
across 100k ohm = 13V
across 200k ohm = 26.7 V
is it correct ?
but it seems to be wrong..
so anyone can help ?
thx
Try breaking the "real" voltmeter, into an ideal voltmeter and the internal resistance of it. How would this configuration look like ;)
actuallt the diagram is
Code:
┌------W (100k ohm) -------------┐
---                                      (200k ohm)
well, the diagram is shown in series
but the question is saying '' across'' ?
so... i don't know ...
Well, you can measure voltage between the two nodes of the resistor, hence you have to put parallel with the resistor, that's what it means by across.
Now how can you split the voltmeter into an ideal voltmeter and its internal resistance?
my anawer:
is it correct ?
thx
We need to see the actual circuit in order to answer the question.
The circuit in post #3 is not displaying properly. Could you do it this way instead:
[noparse]
Code:
{post ciruit diagram here}
[/noparse]
Then we should be able to see what is going on.
kyip, please do all correspondence about this problem by posting here in this thread.
If you have an online image of the circuit diagram:
[noparse][/noparse][i]the URL of the image goes here[/size][/i]
For example, typing
[noparse][PLAIN]https://www.physicsforums.com/customavatars/avatar122961_23.gif[/noparse]
will display this:
Okay, now I can see the updated circuit diagram in post #3.
When the 100 kΩ voltmeter is connected across (i.e., in parallel with the 200 kΩ resistor, that will change the net resistance of that component.
So, first try solving the circuit with the extra 100 kΩ voltmeter there.
