Magnetic field of a circular loop of wire
The discussion focuses on calculating the magnetic field at a point inside a circular loop of wire carrying current, specifically at a distance 'a' from the center, where 'a' is less than the radius 'R' of the loop. The Biot-Savart law is applied, with the equation dB = (μ₀/4π) * (Idℓ × ȳ) / r², where the angle θ between the current element ds and the unit vector ȳ is crucial. The participants emphasize the importance of symmetry in determining the direction of the magnetic field and suggest breaking down the components of the magnetic field into x and y components to simplify the analysis.
  • Understanding of the Biot-Savart law
  • Knowledge of vector calculus
  • Familiarity with magnetic fields and current-carrying conductors
  • Ability to analyze symmetrical systems in physics
  • Study the application of the Biot-Savart law in different geometries
  • Learn how to derive magnetic fields for various current configurations
  • Explore the concept of magnetic field lines and their properties
  • Investigate the effects of varying the distance 'a' on the magnetic field strength
Physics students, electrical engineers, and anyone interested in electromagnetism and the behavior of magnetic fields in current-carrying loops.
tjkubo
I know how to find the magnetic field at the center of a circular loop of wire carrying current. If the radius of the loop is R, how do you find the magnetic field at a distance a from the center of the loop where a<R?
[tex] d{\mathbf{B}} = \frac{{\mu _0 }}{{4\pi }}\frac{{Id{\mathbf{s}} \times {\mathbf{\hat r}}}}{{r^2 }}[/tex]
The small current element ds is always tangent to the loop. r varies from R-a to R+a. The angle θ between ds and [tex]\mathbf{\hat r}[/tex] seems to vary from 90° to some maximum angle that depends on a.
Also, if you define ϕ to be the angle around P from the place you first start to integrate to ds, then [tex]ds\neq rd\phi[/tex].
This is as far as I can analyze. I have no idea what to do with the angles. I am guessing there is some kind of relationship between r and θ or between r and ϕ or between θ and ϕ that I can't see.
First thing you want to do is draw a picture and realize this is a highly symmetric problem. From symmetry you can determine the direction of [itex]\boldsymbol{B}[/itex], draw this vector. Then draw the x and y components. Due to symmetry can you tell what the magnitude of [itex]B_y[/itex] will be? Can you express [itex]B_x[/itex] in terms of B?
Why do you think the angle between [itex]d\boldsymbol{s}[/itex] and [itex]\mathbf{\hat r}[/itex] changes? It does not. So [itex]d\boldsymbol{s} \times \mathbf{\hat r}=ds[/itex].
How does the distance r from the loop to a depend on known variables and does the magnitude of B vary when you rotate over the angle [itex]\phi[/itex]?
Try to enter all information into the Bio Savart law now.
