Partition of Integer need advice
The discussion centers on proving that the number of partitions of an integer \( n \) in \( \mathbb{Z}^+ \) without summands divisible by 4 (denoted as \( P1(x) \)) is equal to the number of partitions where no even summand is repeated (denoted as \( P2(x) \)). The equations for \( P1(x) \) and \( P2(x) \) are established using generating functions. The user proposes a method to find a one-to-one correspondence between the two types of partitions, noting that multiples of four can be transformed into repeated even integers. However, the user identifies a challenge in establishing a unique correspondence, as multiple partitions in \( P1 \) can map to the same partition in \( P2 \).
  • Understanding of integer partitions in combinatorics
  • Familiarity with generating functions
  • Knowledge of the concept of one-to-one correspondence
  • Basic algebraic manipulation of series and products
  • Explore advanced combinatorial techniques for proving partition identities
  • Study generating functions in depth, focusing on their applications in partition theory
  • Investigate the concept of bijections in combinatorial proofs
  • Learn about the theory of partitions and their restrictions, particularly in relation to modular arithmetic
Mathematicians, combinatorial theorists, and students studying partition theory or generating functions who seek to deepen their understanding of integer partitions and their properties.
phoenixy
The Q is: show that the number of partitions of n within Z+ where no summand is divisible by 4 equals the number of partitions of n where no even summand is repeated
Here is what I got so far
Let the partition where no summand is divisible by 4 be P1(x)
Let the partition where no even summand is repeated be P2(x)
My goal is to show that P1(x) = P2(x)
P1(x) = (1+x+x^2 ... )(1+x^2+x^4 ... )(1+x^3+x^6 ...)(1+x^5+x^10 ...)...
(skip x^4, x^8, ... etc.)
P1(x) = [ let i go from 1 to infinity, the products of ( 1 / (1-x^i) ) ] /
[ let i go from 1 to infinity, the prodcuts of ( 1 / (1-x^(4i) )
P2(x) = [ (1+x^2)(1+x^4) ... ][ (1+x+x^2 ...)(1+x^3+x^6) ... ]
P2(x) = [ let i go from 1 to infinity,the products of ( 1 + x^(2i) ) ] *
[ let i go from 1 to infinity, the products of ( 1 / (1-x^(2i-1)) )
So are my equations correct? If so, how do I solve them?
I imagine finding a 1-1 correspondence between the two types of partitions might be easier.
As a start (but just a start, it's definitely not perfect) notice that any partition that has a multiple of four in it can be expressed as a partition that has a repeated integer. Starting with P1, a partition with multiples of 4 in it, simply replace all multiples of fours with two of their halfs, and you get P2, a parition with repeated evens. This is true because any multiple of four is in the form 2 x 2 x k for some k in N. We can clearly replace 2 x 2 x k with two of 2 x k, making 2 x k repeated, and it should be pretty clear that 2 x k is even. However, there are problems. For example, if we have P1 = {4,2,2}, then the corresponding P2 = {2,2,2,2} If we have P1 = {4,4}, the corresponding P2 = {2,2,2,2}, the same as before. This means that for each P1, there exist a P2, but that P2 is not necessarily unique to that P1. If it were, then we could nicely say that if we consider the set of all partitions, the set formed by removing all partitions with multiples of four has the same number of partitions as the set formed by removing all paritions with repeated evens, because for each partition with a multiple of four we remove, we remove one unique parition of the other type. However, this isn't true. You'll have to work around this problem; I'll think about it but this should give you a start.
