System of linear differential equation
The discussion revolves around a system of linear differential equations modeling the motion of a projectile under the influence of gravity and air resistance. The original poster presents the equations derived from the forces acting on the projectile, specifically focusing on the horizontal and vertical components of motion.
  • Exploratory, Problem interpretation, Assumption checking
  • Participants discuss deriving the equations from a free body diagram and the summation of forces. There are attempts to express the equations in terms of position, velocity, and acceleration. Some participants question the method of solving the equations as a system versus individually.
Some participants have offered insights into the approach of separating the equations for the x and y axes, indicating that the equations can be solved independently. There is recognition that the initial setup and assumptions are critical to forming the correct equations, and some participants share their previous experiences with similar problems.
Participants note the absence of similar examples in their resources, which has led to uncertainty in the initial steps. The discussion also highlights the complexity of dealing with non-constant acceleration due to air resistance.
jaredmt
A projectile of mass m is fired at angle theta with the horizontal with initial velocity of v0 (ft/s). neglect all forces except for gravity and air resistance and assume air resistance is equal to k times velocity (ft/s)
a) with x-horizontal and y-vertical, show that the differential equations of the resulting motion are:
mx'' + kx' = 0
my'' + ky' +mg = 0
b) find the solution of the system of differential equations of part (a).
there were no similar examples in the book so i don't know how to do part a... and for part b i tried:
(mD^2 + kD)x = 0
(md^2 + kD)y + mg = 0
im not sure what to do from here or even if that was the right step to begin with
The actual set of equations come from drawing a free body diagram of the projectile, and summing forces on the x and y-axis (one equation for each axis).
As far as solving the equations...i wrote a solution to a similar problem some time ago here on the forum. In it i used
Force of air resistance = α * v,
and for some reason i defined another constant B such that:
B = α / mass
And I assumed it started from a point (0,0) with velocity Vo. Aside from that it should get you on the right track..if not give you the answer :) (from https://www.physicsforums.com/showthread.php?t=241101 ). I also divided through by mass since it is a constant, then the differential equation is in terms of position/velocity/acceleration, something easy to interpret.
swraman said:
The force of the air resistance
Code:
F = α * v
α = a constant, with units Kg/s This depends on the properties of the fluid the projectile it traveling through.
v = velocity
So, net acceleration due to air resistance
Code:
a =  α * v / m
a = Β * v
Β is a constant equal to α / m
since acceleration isn't constant, in order to write the position equations for the X and Y axis you have to start from the beginning.
I am going to do X and Y at separate times, as they can get long.
Y AXIS POSITION EQUATION
(acceleration on y axis) = g + B*(velocity on y axis)
Code:
d2y/dt2 = g + Β*dy/dt
d2y/dt2 - Β*dy/dt = g
Homogeneous solution of the Diffeq.
Code:
y = C1 *e^(Βt) + C2*t*e^(Βt)
for constants C1 and C2.
Boundary conditions of typical projectile problem are
Code:
y(0) = 0
y'(0) = Vo*Sin(θ)
Code:
0 = C1 *e^(Β*0) + C2*0*e^(Β*0)
C1 = 0
The solution becomes
Code:
y =  C2*t*e^(Βt)
Code:
y' =  C2*(t*Β*e^(Β*t) + e^(Βt))
C2 = Vo*Sin(θ)
So now we have the homogeneous solution
Code:
Yh = Vo*Cos(θ)*t*e^(Β*t)
Now the particular solution to the Diffeq:
Code:
Guess Yp = A*t for some undetermined constant A
Code:
Yp = A*t
Yp' = A
Yp'' = 0
0 - Β*A = g
A = -g/Β
Yp = -g*t/B
So now we can write the Y position equation for the projectile with air resistance:
Code:
y = Yp + Yh
[B]y = -g*t/B + Vo*Sin(θ)*t*e^(B*t)[/B]
X AXIS POSITION EQUATION:
Again, we have to start with the acceleration to write the position equation:
(acceleration on x axis) = -B*(velocity on x axis)
Code:
d2x/dt2 = -Β*dx/dt
Since this one is a homogeneus problem, it is much easier to solve:
Code:
d2x/dt2 + Β*dx/dt= 0
x = C1 *e^(-Βt) + C2*t*e^(-Βt)
Again, the innitial conditions for projectile motion:
Code:
x(0) = 0
x'(0) = Vo*Cos(θ)
Plug these in and you get
Code:
C1 = 0
C2 = Vo*Cos(θ)
So, the final equation for the motion on the X axis is
Code:
x = Vo*Cos(θ)*t*e^(-B*t)
Code:
[B][SIZE="4"]y = -g*t/B + Vo*Sin(θ)*t*e^(B*t)
x = Vo*Cos(θ)*t*e^(-B*t)[/B]
thanks for the help
this one was actually easier than it looked. all i had to do was find summation of forces for x and y direction and those were the 2 equations. then solving it was just a matter of doing both equations separately. i was trying to do it as a system of equations, but i don't think it can be done that way since there is no way to even check it as a system of equations
Thats actually what I did. The two differential equations for the x and y-axis are both independent of each other, and i solved them spearatley ;)
  • · Replies 27 ·
