Magnitude and Direction of Magnetic Field
The discussion revolves around calculating the magnitude and direction of the magnetic field generated by two long straight wires carrying current. The problem includes specific distances between the wires and the point of interest where the magnetic field is to be determined.
  • Mathematical reasoning, Assumption checking
  • Participants discuss the application of the magnetic field formula and the significance of using standard units for distance. There is an attempt to verify the calculations and the correctness of the answer provided by the original poster.
The conversation has progressed with participants confirming the calculations and addressing unit conversion. There is a collaborative effort to ensure the accuracy of the magnetic field's magnitude and direction, but no final consensus on the correctness of the answer has been explicitly stated.
Participants are reminded to express distances in standard units, indicating a focus on proper unit usage in the calculations. The original poster's initial answer was questioned, leading to a revision based on this feedback.
hardwork
Two long straight wires each carry 3.4 A of current and are crossed, as shown in the figure. If Dh=12.0cm and Dv=6.0cm, what is the magnitude and direction of the magnetic field at A? Figure: http://i41.tinypic.com/4louv6.jpg"
B=(Mu)(I)/(2pie)(r)
B = [(4pie x 10^-7 Tm/A)(3.4A)]/(2pie) x (1/6.0cm - 1/12.0cm)
B = 5.7 x 10^-8 T out of page
Would someone be able to please check if that is the correct answer? Thank you!
Almost. Express those distances in standard units.
Oh, right. Thank you!
B = 5.7 x 10^-6 T out of page
Good!
9K
