Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
Go Back   Physics Forums > Mathematics > Number Theory
Reply
image general form of prime no.s Share It Thread Tools Search this Thread image
Old Apr13-09, 12:11 PM                  #1
chhitiz
chhitiz is Offline:
is there any other general form of prime no.s known except 6n+/-5 and 6n+/-1. is there any general form of n such that 6n+/-5 or 6n+/-1 is a composite no.?
Old Apr13-09, 01:00 PM                  #2
matticus
matticus is Offline:
Re: general form of prime no.s
4n+/-1
6n+/-1 is composite iff there are nonzero integers a and b such that n = 6ab + a + b.
for instance 6(4) + 1 is composite since 4 = 6(-1)(-1) + (-1) + (- 1)
Old Apr13-09, 02:59 PM                  #3
CRGreathouse
CRGreathouse is Offline:
Recognitions:
Homework Helper Homework Helper
As many as you'd like. 2n + 1, for example.
n = 141.
n = 5k.
n in {1, 4, 5, 6, 8, 9, 10, 11, 12, 13, 14, 15, 16, 19, 20, 21, 22, 23, 24, 25, ...}
n in {k | k - 5, k - 1, k + 1, or k + 5 can be written as ab with 1 < a <= b}
Assuming, of course, that we interpret your statement identically.
Old Apr14-09, 04:37 AM                  #4
chhitiz
chhitiz is Offline:
but, then, if i am not wrong, this series doesn't have a pattern, does it?
what i meant by my question was if there is a general form or, a set of general forms which can represent each and every prime no. exhaustively.
Old Apr14-09, 09:32 AM                  #5
CRGreathouse
Recognitions:
Wow, impredicativity in real life!
The sequence has a pattern, it's stated just below it.
Old Apr14-09, 10:50 AM                  #6
chhitiz
chhitiz is Offline:
i should've asked this earlier, i have no idea what that line between n and k stands for. so i can't understand what this statement means.
Old Apr14-09, 11:13 AM                  #7
CRGreathouse
Recognitions:
"such that"
Old Apr14-09, 11:50 AM                  #8
chhitiz
chhitiz is Offline:
oh now i get it.but that just comes directly from the definition of prime no.s.
let me rephrase my original question- is there any general form/set of forms an+/-b which expresses every prime no. exhaustively, barring the cases where n=ck+/-d where a,b,c,d are constants and n,k integers>=0. i repeat again, this set of forms should represent every prime no. exhaustively.
Old Apr14-09, 12:06 PM                  #9
CRGreathouse
Recognitions:
Sure, r for r a real number. Also r^2 + pi/2 (but not r^2 + pi). Also a^2 + b^2 + c^2 + d^2 for a, b, c, and d integers.
Old Apr16-09, 06:48 AM                  #10
chhitiz
chhitiz is Offline:
but then if a=b=c=d=1, we get 4. how is this prime? and, is it r^(2+pi/2) or r^2+pi/2
Old Apr16-09, 10:43 AM                  #11
CRGreathouse
Recognitions:
6n+1 for n = 4, how is this prime?
You asked for forms that cover all the primes, not for forms that were only prime.
I intended the second, but both work.
Old Apr16-09, 12:12 PM       Last edited by matt grime; Apr16-09 at 12:33 PM..            #12
matt grime
Math Guru 2008
matt grime is Offline:
Recognitions:
There is no choice of a and b so that an+b is prime for every n.
There is no choice of a and b (except for the trivial a=1 b=0 type) so that every prime is of the form an+b for some n (above you'll note that you have a collection of choices that will give every prime, with exceptions such as 2 and 3 for the 6n+1 and 6n-1 case).
The 'pattern' of the primes is entirely deterministic (sieve of what's-his-face) and simultaneously very hard to prove anything about (e.g. twin prime conjecture).
At least that is what I think you're getting at.
Old Apr17-09, 07:11 AM       Last edited by chhitiz; Apr17-09 at 07:22 AM..            #13
chhitiz
chhitiz is Offline:
i'm not sure but i think i found a set of 8 forms an+b which express every prime except 2,3,5.
and each of these forms have exceptions, ie values of n for which no. is composite, based on integer solutions of set of quadratic eqns in two variables. i will work them out probably in a day or two after the damned sessionals are over. is this a new approach or has someone already done this?
ps- what is sieve of what's-his-face?
Old Apr17-09, 10:00 AM                  #14
CRGreathouse
Recognitions:
By 8 you mean {1, 7, 11, 13, 17, 19, 23, 29} mod 30. Yes, all primes greater than 5 are of that form. What's more, almost all numbers of this form are composite -- only a tiny fraction are prime.
You can go a step higher if you'd like. All primes greater than 7 are {1, 11, 13, 17, 19, 23, 29, 31, 37, 41, 43, 47, 53, 59, 61, 67, 71, 73, 79, 83, 89, 97, 101, 103, 107, 109, 113, 121, 127, 131, 137, 139, 143, 149, 151, 157, 163, 167, 169, 173, 179, 181, 187, 191, 193, 197, 199, 209} mod 210.
Like (a + 1)(b + 1) for positive integers a, b?
It's about two to three thousand years old. I'm fairly sure it wasn't known 4000 years ago.
The sieve of Eratosthenes.
Old Apr17-09, 10:55 AM                  #15
Count Iblis
Count Iblis is Online:
Recognitions:
There does exist a polynomial in 26 variables that generates all the primes, see here.
Old Apr18-09, 08:08 AM       Last edited by chhitiz; Apr19-09 at 01:25 AM..            #16
chhitiz
chhitiz is Offline:
well, yes. it goes something like this-
30n+7 is prime for all n except when n is of form
30k1k2+7k1+k2
30k1k2+17k1+k2+6
30k1k2+23k1+29k2+22
30k1k2+13k1+19k2+8
image image
Reply
Thread Tools
Similar Threads for: general form of prime no.s
Thread Thread Starter Forum Replies Last Post
Help finding a transition matrix between the Jordan form and a general form Quantumpencil Calculus & Beyond 5 Nov16-08 10:08 PM
Question about the General form to normal form of Diff Eq Saladsamurai Calculus & Beyond 1 Jan27-08 11:43 PM
general form Chocolaty Calculus & Beyond 4 Dec19-05 01:48 AM
General Definition of Relatively prime snoble Linear & Abstract Algebra 11 Apr20-05 02:32 PM
Powered by vBulletin Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
