A fixed cannon is to fire a projectile at a tank
The discussion focuses on calculating the correct firing angle for a fixed cannon to hit a tank moving towards it at 40 mph, starting from a distance of 8 miles. The projectile's muzzle speed is 1000 mph, and the relevant equations involve the projectile's position and velocity components. The solution requires eliminating time from the equations of motion, leading to the equation (3.16*cos(theta)+0.127)*sin(theta)=1, which is the target result for determining the firing angle.
  • Understanding of projectile motion equations
  • Familiarity with trigonometric functions and their applications in physics
  • Knowledge of calculus, specifically integration for velocity and position
  • Basic principles of kinematics, including acceleration due to gravity
  • Study the derivation of projectile motion equations in physics
  • Learn techniques for eliminating variables in equations, particularly time
  • Explore the application of trigonometric identities in physics problems
  • Review kinematic equations and their use in real-world scenarios
Physics students, engineers, and anyone interested in solving projectile motion problems, particularly in the context of targeting moving objects.
esmmajor
1. Problem Statement:
A fixed cannon is to fire a projectile at a tank moving toward the cannon at 40 mph. If the cannon is to fire at the moment the tank is 8 miles from the cannon, and the muzzle speed of the projectile is 1000 mph what is the correct equation to determine the firing angle?2. Homework Equations :
Acceleration of gravity: 79000 m/h^23. Solution Attempt:
Initial conditions:
r=<8-40t,0>
v=<1000*cos(theta), 1000*sin(theta)>
started with:
acceleration_projectile=<0,-g>
<0,-79000.
velocity (took integral and used initial conditions to come up with constants)
v=<1000*cos(theta), -79000t+1000*sin(theta)>
position:
r=<1000*cos(theta)*t+t-40t, -79000t^2/2+1000*sin(theta)t>
**The answer I'm supposed to get is (3.16*cos(theta)+0.127)*sin(theta)=1
Any help would be greatly appreciated.
Hi, esmmajor.
Well, you are right for every step. Except that, at some point, you want to eliminate t.
My personal suggestion would be:
in x direction, how would you relate the velocity of the particle to the time and distance?
and in y direction, how are you going to relate the initial velocity to the acceleration and time?
And finally, are these two time t, equal?
Have an idea of how to eliminate the t?
  • · Replies 24 ·
