Physics Word Problem; Projectile Motion
The problem involves projectile motion, specifically analyzing the time it takes for a ball thrown by a catcher at an angle of 30 degrees to reach second base, a distance of 120 feet. Participants are exploring the application of kinematic equations and trigonometric relationships in this context.
  • Mixed
  • Participants discuss the use of kinematic equations and the need for two equations to solve for time due to the presence of two unknowns. There is also a suggestion to consider both horizontal and vertical components of motion in the analysis.
Some participants have provided calculations for velocity and time, while others have raised questions about the completeness of these calculations, particularly regarding the horizontal component of velocity. There is an ongoing exploration of different approaches to the problem.
Participants note the constraints of using specific equations and the importance of verifying assumptions about the motion, such as the height at which the ball is thrown and caught.
georgiaa
Suppose a catcher is crouched down behind the plate wen he observes the runner breaking for second. After he gets the ball from the pitcher, he throws as hard as necessary to second base without standing up. If the catcher throws the ball at an angle of 30 degrees from the horizontal so that it is caught at second base at about the same height as that catcher threw it, how much time does it take for the ball to travel the 120 ft from the catcher to second base?
v= d/t
The big 5 equations
sine law
cosine law
pythagorus
X = 120 feet
V = velocity at which ball was thrown
Θ = 30 degrees
g = acceleration due to gravity = 32.2 ft/sec^2 (constant)
120 = V^2(sin 2*30)/32.2
V = sqrt (120*32.2/sin 60)
V = 66.80 ft/sec.
T = 120/66.80
T = 1.80 sec.
I'm not sure if this is right...is there an easier solution using the formulas provided above?
v= d/t
The big 5 equations
sine law
cosine law
pythagorus
X = 120 feet
Θ = 30 degrees
V = 66.80 ft/sec.
T = 120/66.80
T = 1.80 sec.
Looks right (66.7696 f/s) for velocity, But I think you haven't used the horizontal component of velocity. Looks like you used Vo to figure the time.
Wow, this is a fun little question. Here's an idea (double check this yourself - don't trust it!):
In the horizontal direction:
d = vt + .5at^2
120 = vt + 0
So horizontal velocity is:
v = 120 / t
So vertical velocity is:
v = (tan30) x horizontal velocity
v = (tan30) x 120 / t
Now in the vertical direction:
d = vt + .5at^2
0 = (vertical velocity x t) + .5(-32.2)t^2
t = ?
Edit - removed complete solution as per forum rules.
  • · Replies 18 ·
  • · Replies 16 ·
