Solving for f'(g(0))g'(0) in the Inverse Function of f
  • Thread starter Thread starter coookiemonste
    Derivative
The discussion revolves around finding the value of f'(g(0))g'(0) where f(x) = x^3 - x - 6 and g is the inverse function of f. Participants are exploring the relationship between a function and its inverse, particularly focusing on the derivatives involved.
  • Some participants question the assumption that g(x) can be represented as 1/(x^3 - x - 6), noting that this is not the correct form for the inverse function. Others discuss the implications of the derivative of the inverse function and the relationship between f(g(x)) and x.
Participants are actively engaging with the problem, with some providing insights into the nature of inverse functions and their derivatives. There is a recognition of the need to clarify the correct form of g(x) and how it relates to the derivatives being calculated. Multiple interpretations of the problem are being explored.
There is an ongoing discussion about the correct approach to finding the inverse function and its derivative, with some participants suggesting that the original poster may need to reconsider their assumptions and methods. The conversation reflects a mix of attempts to clarify definitions and explore mathematical reasoning.
coookiemonste
If f(x)=x^3-x-6 and g is the inverse function of f.
what is f'(g(0))g'(0)?
the answer is 1...but I am not sure how to get that.
[f(g(x))]'=f'g(x)*g'(x)
i wasnt quite sure, but i assumed g(x)=1/(x^3-x-6)
^is this assumption right?
then f'(x)=3x^2-1
i also set f(x)=0 to find x=2.
but for g(0) i get -1/6
so for f'(g(0))g'(0)= i get -1(-1/6)*(-1) = -1/6
but this is incorrect.
An inverse function can be found by switching the positions of the x and y variables of a function and (to put it in true function form) solving for y.
For example, if we have
[tex]f(x) = y = 3x -1[/tex]
and we want to find the inverse of f, which we can call g, these are the steps to take:
1. Switch the positions of the x and y variables:
[tex]x = 3y - 1[/tex]
2. Solve for y:
[tex]x + 1 = 3y[/tex]
[tex]\frac{1}{3}x + \frac{1}{3} = y[/tex]
So we have,
[tex]g(x) = \frac{1}{3}x + \frac{1}{3}[/tex]
Now, watch what happens if we take f(g(x)):
[tex]f(g(x)) = f(\frac{1}{3}x + \frac{1}{3})[/tex]
[tex]= 3(\frac{1}{3}x + \frac{1}{3}) - 1[/tex]
[tex]= x + 1 - 1[/tex]
[tex]= x[/tex]
Similarly, if we try g(f(x)):
[tex]g(f(x)) = g(3x -1)[/tex]
[tex]= \frac{1}{3}(3x -1) + \frac{1}{3}[/tex]
[tex]= x - \frac{1}{3} + \frac{1}{3}[/tex]
[tex]= x[/tex]
This happens with any function and its true inverse. If we take the composite of a function and its inverse in either directions (i.e. f(g(x)) of g(f(x)) ), we end up getting x back. Or in the case of a number, e.g. f(g(1)) = g(f(1)) = 1
An inverse function basically "undoes" whatever a function does to a number.
So, your g(x) is not correct. And you may not always be able to easily find the inverse of a function solved for y, as is true with the function you have been given.
That being said, there are a couple ways to solve your problem.
The quickest way is to try playing around with the formula you gave under "relevant equations," to see if any expression simplifies, then take it from there.
Otherwise, you can look up a formula for the derivative of an inverse function to find g'(x) by skipping right to the derivative of an inverse function without finding the inverse. It can be found in any calculus textbook.
In case it wasn't abundantly clear from what Meiso said, the inverse of f(x) is not 1/(x^3 -x - 6). This is the reciprocal of f(x), but not its inverse.
then f'(x)=3x^2-1
so if f(g(x))=x
and [f(g(x))]'=(x)'=1
is this correct?
coookiemonste said:
so if f(g(x))=x
is this correct?
Yes.
coookiemonste said:
so if f(g(x))=x
is this correct?
Exactly right. And, sorry, I thought I was clear enough when I said,
You were clear, but what you said was a little hard to find, being about 30 lines down in your post.
When a post is written in response to a user asking for homework help, I would assume that the original poster is going to read the response in its entirety (which, from his response, it seems he did), so I don't think about whether a certain item will be hard to "find" while I'm writing it.
IMO, it's better to answer the question right at the beginning, and follow it with any explanatory material.
thank you!
