| Thread Closed |
Structural engineering |
Share Thread | Thread Tools |
| Apr16-09, 07:34 AM | #1 |
How can i find deflection in simply supported beam with multiple point loads ?
| Apr16-09, 09:31 AM | #2 |
Recognitions:
Superposition
| Apr30-09, 12:48 PM | #3 |
you can simply find the deflection for beam loaded with UDL, or you can put your load in the computerised model.
| Apr30-09, 07:18 PM | #4 |
thanks for reply,
but what u will do when u have so many point load acting on beam and u have to find solution manualy and quickly. |
| May1-09, 01:37 AM | #5 |
I would use the simple software Winbeam. This is an excellent tool for calculating max. moment etc. on beams with any kind of loadings. - Well, this can give the deflection, if the stiffness factor is correct inserted. Normally I don't use this program to calculate deflection - but it is possible as far as I know. I have a quite old version of the program - maybe a new version have even better features for calculating deflection.
| May1-09, 07:13 AM | #6 |
Recognitions:
You take the response of the beam based on each load seperately, then just add them together. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Structural engineering
| CS to Civil/Structural Engineering | Academic Guidance | 8 | ||
| Structural engineering help | Engineering, Comp Sci, & Technology Homework | 1 | ||
| difference between structural and mechanical engineering | General Engineering | 2 | ||
| Structural Engineering - Deflection | General Engineering | 8 | ||
