Register to reply
Deflection of box section - result Discrepancies
by Mech King
Tags: deflection, discrepancies, result
Share this thread:
Mech King
#1
Apr17-09, 10:29 AM
P: 73
Hello everyone,
I have a beam deflection problem. I haven’t looked at deflections for a while now and I cant understand why my solution is a million miles out fro the results I have seen through testing.
Problem:
I have a beam made from 100x40x3mm mild steel box section which is 2100mm in length. See attached figure for free body diagram of the loading on the beam. Please note the loads P1, P2 and P3 are applied individually and then removed before applying another load, so there is only one load on the beam at any one time.
The beam is welded to the supports underneath the beam (labeled “support reactions”)
The beam is loaded against its widest face and hence I have used the “second moment of area” value as given from the data sheet in its Y axis.
Relevant formulas:
E=200,000 N/mm2 for steel
I = 361000 mm^4
Solution:
My first load case is the individual force P1 applied to the left hand side of the beam:
P1=22,017N
Cantilever moment load (as per Shigley’s Mech eng Design book):
Ymax = (M*L^2)/2EI
Ymax = [(22017*177.5^2)*177.5^2]/(2*E*I)
Ymax = 0.86 mm
Query of Solution:
I have had this problem tested and the deflection of the beam was 6.77mm. My results are showing a figure which is about 8 times too small?
Could somebody please help me understand where I am going wrong?
I have a similar problem with the remaining two load case scenarios set out in the free body diagram, for loads P2 and P3 also, but I wanted to clear up this scenario here before progressing.
What do you think?
Phys.Org News Partner Science news on Phys.org
World's largest solar boat on Greek prehistoric mission
Google searches hold key to future market crashes
Mineral magic? Common mineral capable of making and breaking bonds
minger
#2
Apr17-09, 02:29 PM
Sci Advisor
P: 1,498
Well, you don't have a pure moment load. You have an applied shear load, which will then cause a moment.
I assume you're looking at the Appendix, Table A-9.4 Cantilever - moment load. If you notice, it shows the reaction force at the fixed support [tex]R_1 = 0[/tex]. You will surely have a reaction. I don't see any cases in there which match yours. You may have to do this the ol' fashioned way, through integration. Are you familiar with shear/moment diagrams and analytic methods for calculating these things?
Mech King
#3
Apr18-09, 04:19 AM
P: 73
Hi Minger,
Thanks for the reply.
I am familliar with these methods but havent looked at them since university so im a little rusty. I will give it a shot this weekend and show you the results. Im guessing you are familliar with therse methods?
Cheers
minger
#4
Apr20-09, 10:25 AM
Sci Advisor
P: 1,498
I also haven't done exactly that in quite some years. From what I remember though, it's as simple as integrating the shear load 4 times and applying the correct boundary conditions as the constants of integration. I may be mistaken though...
Register to reply
Related Discussions
Deflection of a beam with non-uniform section Mechanical Engineering 5
How to calculate section modulus of channel section Mechanical Engineering 2
What is the result Set Theory, Logic, Probability, Statistics 2
An unlikely result General Math 5
Links section not working — and some nexus-prime discrepancies Forum Feedback & Announcements 5
