Thread Closed
Optics Experiment
Share Thread Thread Tools
Apr18-09, 02:28 PM   #1
Optics Experiment
1. You are given the following equipment for use in the optics experiments in parts (a) and (b).
- A solid rectangular block made of transparent plastic
- A laser that produces a narrow, bright, monochromatic ray of light
- A protractor
- A meter stick
- A diffraction grating of known slit spacing
- A white opaque screen
(a) Briefly describe the procedure you would use to determine the index of refraction of the plastic. Diagram?
(b) Since the index of refraction depends on wavelength, you need to determine the wavelength of your light source.
2. Dark Slits vs. Bright Slits
c=fλ
Path Difference: Δl = dsinθ
Bright Fringe: dsinθ =mλ
Dark Fringe: dsinθ = (m-1/2)λ
3. Does this all have to do with Young's Two Slit Experiment? Setting up something that will create an interference pattern and then using that to determine other things..?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Front-row seats to climate change
>> Attacking MRSA with metals from antibacterial clays
>> New formula invented for microscope viewing, substitutes for federally controlled drug
Apr18-09, 10:58 PM   #2
Quote by pfforum View Post
Yes. The equation d*sin(theta) = m*lamda that gives the maxima for Young's experiment is the same equation for a diffraction grating.
Your problem is to determine the index of refraction of the plastic. Here are some key questions you need to answer. What happens to the wavelength of light when you pass it through some material other than a vacuum? What is the behavior among wavelength and the angles associated with maxima in Young's interference experiment?
Apr19-09, 12:02 AM   #3
Recognitions:
Homework Helper Homework Help
Using diffraction grating form the interference pattern on the white screen. Mark the central and first order bright spot. Draw a perpendicular from central bright spot to position of the grating. Join the point of intersection of these to to the first order bright spot. That gives you the angle θ. Now place the plastic block in the path of the ray and parallel to the screen. Mark the new position of the first order bright spot. From this point draw a parallel line to the initial path of the ray. Find the distance between them. That is the lateral shift. Find the expression for the lateral from any book and find refractive index of the plastic slab.
Thread Closed
Tags
optics experiment
Thread Tools
Similar Threads for: Optics Experiment
Thread Forum Replies
Angle Of Deviation - An Optics Problem, help needed in optics General Physics 6
microwave optics experiment Advanced Physics Homework 1
Help with Mock Optics Experiment General Physics 1
A Fourier Optics experiment General Physics 7
z scan experiment in non linear optics General Physics 0
