Relation between (simplified) elastic d. eqn. and classical schrodinger eqn?
In summary, the classical Schrodinger equation and the elastic differential equation have similarities in their mathematical forms, as both can be reduced to ODEs in certain cases, and it is mainly due to historical reasons that the elastic equation is often referenced when discussing the Schrodinger equation.
dev00790
Hello,
I wondered if someone could help me show / give hints on how to show the (simplified) elastic differential equation (below) is related to the classical Schrodinger equation (in quantum mechanics)? I am a maths undergraduate.
2. Homework Equations - (i had some trouble with tex/latex while writing these. By "pd" I mean partial derivative :smile:
(simplified) elastic differential equation: [tex]$d^2y/dx^2 + \lambda^2g(x)y=0$[/tex]. Assumtion: the value of Lambda tends to infinity. Also: [tex]$g(x)>=g(0)>0$[/tex]
What i believe is the classical schrodinger equation (?):
[tex]$[[-h^2/2m][pd^2/pdx^2] + V(x)$](\phi)=E(\phi)[/tex], 3. My Attempt
I have got so far: [tex]$[[-h^2/2m][pd^2/pdx^2] + [1/2][kx^2]](\phi)=E(\phi)$[/tex]Assuming (perhaps incorrectly that potential function V(x) is: [tex]$V(x)=(1/2)kx^2$[/tex] for system, [tex]$\phi$[/tex] is the wavefunction, and [tex]$[[-h^2/2m][pd^2/pdx^2] + V(x)[/tex] is Hamiltonian operator.
I don't know how to show they are similar. - Main concern is in schrod. equation (PDE) phi is being operated on, wheras in elastic eqn (ODE) y(x) is either a part of a product not operated on or is in other term. I can see that k = lambda^2.
Thank you
dev00790
Hello! I wish I could do some help(translate the tex codes into visual formula).
The Schrodinger equation(SE) discribes the dynamical evolution of a plane wave or a wave packet. For a 1-dimensional particle confined in potential $V(r)$, it's SE reads:
-\frac{\bar{h}^2}{2m}\frac{\partial^2\Phi}{\partial x^2}+V(x)\Phi=i\bar{h}\frac{\partial\Phi}{\partial t}=i\bar{h}\frac{\partial\Phi}{\partial t}
If the SE doesn't contain time explicitly(EXPLICITLY!), the 1D SE could be solved via separation of variables, and after some algebra, we have:
\Phi(x,t)=\Psi(x)e^{-Et/\bar{h}}
where $\Psi(x)$ depends only on $x$ and satisfies the SE for stationary state(SESS):
\left[-\frac{\bar{h}^2}{2m}\frac{d^2}{d x^2}+V(x)\right]\Psi=E\Psi
$$-\frac{\bar{h}^2}{2m}\frac{d^2}{d x^2}\Psi+(V(x)-E)\Psi=0
So, before further analyses, SE turns into ODE now, just like the elastic equation. Hence, the confusion of the analogy between PDE(SE) and ODE cancels.
Now, I would argue that the relation between the elastic ODE and the SESS is just mathematical(MATHEMATICAL!), and the very reason for which we refer to Elastic ODE is simply a tradition for the comparison of Schrodinger's wave mechanics with Heisenberg’s matrix mechanics! In late 1925, Heisenberg put forward the first approach to quantum mechanics with the mathematical methods of matrix algebra, which was completely new to physicists at that time. Yet, a few months later in early 1926, Schrodinger came up with the second approach using PDE method, which had been quite a popular tool for physicists. Heisenberg and Schrodinger ran into hot debate to confirm that one's own method is better than the other. However, indeed people quite preferred Schrodinger's approach rather than Heisenberg's initially, though they began to learn and utilize matrix algebra gradually. SE is firstly put into use with hydrogen atom and some special potentials such as in harmonic oscillations and square wells. On these occasions, for 1-dimensional cases, we could get the SESS as above, which is easy to handle, just with the standard steps of solving 2-order homogeneous ODE, which we come across time and again in oscillating mechanical models. It is on this consideration that we relate SE with the elastic ODE, which indicates implicitly the ever being hot debating.
As for SE for 3-dimensional particles, we always employ spherical coordinates, and separate the three variables to get sub-equations. AS for the angular componential one, we meet with the 2-order ODE like the elastic ODE again.
By the way, concretely, for 1-dimensional harmonic oscillator, it's correct for you to set $$V(x)=\frac{kx^2}{2m}$$ (with origin at the equilibrium point), so does the Hamiltonian.
1. What is the simplified elastic differential equation?
The simplified elastic differential equation is a mathematical representation of the behavior of elastic materials under stress. It relates the strain (deformation) of a material to the stress (force) applied to it.
2. What is the classical Schrodinger equation?
The classical Schrodinger equation is a fundamental equation in quantum mechanics that describes the behavior of a quantum system over time. It relates the wave function of a particle to its energy and potential energy.
3. How are the simplified elastic differential equation and the classical Schrodinger equation related?
The simplified elastic differential equation and the classical Schrodinger equation are both partial differential equations that describe the behavior of a physical system. They are related through their mathematical structure and can be solved using similar techniques.
4. What are the main differences between the simplified elastic differential equation and the classical Schrodinger equation?
The main difference between these two equations is their application. The simplified elastic differential equation is used to study the behavior of macroscopic materials, while the classical Schrodinger equation is used to describe the behavior of subatomic particles. Additionally, the simplified elastic differential equation is a classical equation, while the Schrodinger equation is a quantum mechanical equation.
5. How are the simplified elastic differential equation and the classical Schrodinger equation useful in scientific research?
Both equations are fundamental in their respective fields and have been used extensively in scientific research. The simplified elastic differential equation is used in fields such as engineering and materials science, while the classical Schrodinger equation has applications in physics, chemistry, and other fields. These equations allow scientists to make predictions and understand the behavior of physical systems, leading to advancements in technology and our understanding of the natural world.
