Solving pH Changes in Buffer Initial pH 4.45
  • Thread starter Thread starter lha08
    Buffer
The discussion focuses on calculating the pH changes in a buffer solution when 1.00 mL of NaOH is added to 35 mL of water, starting from an initial pH of 4.45. The measured pH after adding NaOH is 11.14, while the pH remains at 4.73 when no NaOH is added. The lack of information regarding the buffer concentration and type renders the problem incomplete, as these factors are crucial for accurate pH calculations.
  • Understanding of buffer solutions and their properties
  • Knowledge of pH, pOH, and the relationship between [H+] and [OH-]
  • Familiarity with strong base behavior, specifically NaOH
  • Basic skills in stoichiometry and molarity calculations
  • Research the Henderson-Hasselbalch equation for buffer pH calculations
  • Learn about the effects of strong bases on buffer systems
  • Study the concept of buffer capacity and its implications in pH stability
  • Explore the significance of buffer concentration and type in pH calculations
Chemistry students, educators, and anyone involved in laboratory work related to buffer solutions and pH calculations.
lha08
If the initial buffer pH is 4.45, what is the pH when 1.00 mL NaOH is added to 35 mL of water?
Also, if 0.0 mL NaOH is added, what is the pH then?
I have no idea how to do this...all i can think of is to change the pH to [H+] and add the moles of that with the moles formed by NaOH (i tried using OH and using its pOH and finding the pH and converting back to H+) but when i add them together and divide by the total volume it's wrong...supposedly the measured pH for the addition of 1.00 ml is 11.14 and for the 0.00 added it's 4.73..thanks
You are not given buffer concentration, nor buffer type? Then there is no answer to this question.
This one is easier. Once you add 0.0 mL of a strong base, pH doesn't change. But I suppose that's just a typo :smil:
Problem description is incomplete. Are you trying to solve a general problem?
  • · Replies 23 ·
  • · Replies 16 ·
  • · Replies 22 ·
