Register to reply
HELP L-shaped tank problem!
Share this thread:
azrida
#1
Apr19-09, 01:34 PM
P: 8
The L-shaped tank shown below is filled with water and is open at the top.
(a) If d = 7.0 m, what is the force on face A due to the water?
(b) What is the force on face B due to the water?
2. Relevant equations
F=PA
P=pgh
3. The attempt at a solution
I've got the (a) part right: pgd*A = 1000*9.8*14*49 = 6722800.
However, I don't have a clue how I can get pressure on face B!
I tried setting distance as 3d = 21 and 4d = 28, and area as d^2 = 49, but nothing seems to work.
The answer is supposed to be 8.40e+06.
I need to know this for exam on Tuesday.
Please, HELP!!!!!!!
picture's at http://www.webassign.net/hrw/hrw7_14-33.gif
Phys.Org News Partner Science news on Phys.org
Experts defend operational earthquake forecasting, counter critiques
EU urged to convert TV frequencies to mobile broadband
Sierra Nevada freshwater runoff could drop 26 percent by 2100
LowlyPion
#2
Apr19-09, 03:56 PM
HW Helper
P: 5,341
No image, so I have no idea either.
azrida
#3
Apr19-09, 04:15 PM
P: 8
Quote Quote by LowlyPion View Post
sorry, the picture's at http://www.webassign.net/hrw/hrw7_14-33.gif
LowlyPion
#4
Apr19-09, 04:37 PM
HW Helper
P: 5,341
Face B is a vertical face. Hence the pressure changes with depth.
So consider then the average force across the B face between 2d and 3d times the area.
azrida
#5
Apr19-09, 04:55 PM
P: 8
So, do I do 2.5d..?
And 2.5d seems to do the trick since I got the correct answer with it:
F = PA = pgdA = 1000*9.8*(2.5*7)(7*7) = 8403500 N
Thanks a bunch :-) !!!
LowlyPion
#6
Apr19-09, 06:58 PM
HW Helper
P: 5,341
Yep. You got it.
syazwanadzhar
#7
Aug28-11, 04:05 PM
P: 1
well, it is actually not 2.5D. the more precise working is integrating.
let pgh be the function where p and g is constant. Hence, you can integrate h where the upper boundary is 3D and the lower boundary is 2D. The answer would be more or less the same if you use 2.5D but better luck next time, you might need this :)
Register to reply
Related Discussions
U-shaped tube, pressure problem, what am i doing wrong? please help Introductory Physics Homework 1
U-Shaped Tube Pressure Problem Introductory Physics Homework 6
Tank Problem - Pump at the END? Advanced Physics Homework 3
Differential equation tank problem Differential Equations 5
Propane Tank problem Introductory Physics Homework 1
