Calculating the Probability of an Ideal Gas in Half its Volume
The discussion revolves around calculating the probability of all molecules of one mole of an ideal gas being found in half of its volume. Participants explore combinatorial reasoning related to particle distribution in a defined space.
  • Participants discuss the setup of the problem, questioning how to apply combinatorial methods to determine the probability. There are attempts to clarify the distinction between ordering particles and assigning them to different sides of a volume.
Some participants have offered guidance on how to approach the problem using combinatorial reasoning, while others express confusion about the application of the "choose" operation and the implications of the total number of configurations. Multiple interpretations of the problem are being explored.
There is an ongoing discussion about the assumptions underlying the combinatorial setup, including the nature of the particles and the physical implications of the calculated probabilities.
latentcorpse
What is the probability that at one instant, in one mole of an ideal gas, all [itex]N=N_A[/itex] molecules will be ofund in a volume [itex]\frac{V}{2}[/itex]? Express your answer as a power of 10?
usually this type of question is just a simple combinatorics question but i don't know how to set it up. i.e. how do i make it "something choose something"
i thought there was some information missing to be honest but it's a past exam question so I'm assuming it's legit...
Divide the volume in your mind into half. How many ways can you distribute N particles into these two halfs? How many of these ways have all particles in one half? The ratio of these two numbers is the required probability. If you have one mole of gas, then the number of molecules N is the Avogadro number.
at a guess there's N! ways of arranging N distinguishable objects
only 1 of these will have all in one half so the answer is just N! yeah?
No it's not N! ways. N! is the number of ways of ordering N distinguishable objects in a line. We don't want to order the particles, but just to assign to each of them either "left side" or "right side". How many ways are there of doing that?
[itex]\binom{N}{n_R} \binom{N-n_R}{n_L}[/itex] but the second coeffeicient will just be one will it not as [itex]n_L=N-n_R[/itex]
is this right? i just found the same question again and still haven't really grasped what's going on.
There are two ways to assign and L or an R to particle one, i.e. just L and R. Once you assign a side to particle one, there are two ways to assign a side to particle two, so for each of the two possible choices for particle one, there are two ways for particle two. This gives four ways for both: LL, LR, RL, RR. Can you see how to extend this reasoning to N particles?
2N possible combinations
i want 1 particular one (i.e. all on one side)
therefore [itex]\binom{2N}{1}=2N[/itex]
Check your result for three particles:
LLR
LLL
LRR
LRL
RLR
RLL
RRR
RRL
There are 8 ways. But your formula 2N gives 2(3) = 6. Read post #7 again carefully and try to extend the logic to three particles, and you'll see the pattern.
ok 2^N then but i still only want to choose one of those combinations (i.e. all on one side) so i have 2^N choose 1=2^N ways of doing this.
There is only one way to assign "left" to all of them: (LLLL ... L). Be careful about what the "choose" operation means. N choose k is the number of ways of choosing a subset of k elements from N. Here, we don't want the number of ways to choose one element from 2^N, we just want the number of ways in which all of the N particles are on one side. They can all be either on the left side, or all on the right, so there are just two ways of doing it. The required probability is therefore 2/(2^N).
ok. i kind of follow that argument. but still a little hazy about why we can't use the choose argument - clearly it gives a high probability which is unphysical but surely there are 2^Npossible configurations and we want to choose 1 of them?
We want to count how many of them have all particles on one side. The technical meaning of "N choose k" is "the number of ways of selecting a subset of k elements from a set of N elements." Are we looking for the number of ways of choosing 1 element from a set of 2^N elements? No! We just want to count how many of them satisfy our condition "all on one side".
  • · Replies 69 ·
9K
14K
