Are conduction electrons localized in space?
The discussion revolves around the localization of conduction electrons in metals, exploring whether they are localized in space or delocalized. Participants examine various models, including the infinite square well and Bloch waves, and consider implications for electron behavior in solid-state physics.
  • Some participants propose that conduction electrons are delocalized in space and localized in momentum space, aligning with the energy-band picture and Fermi-Dirac statistics.
  • Others argue against the use of the infinite square well model for metals, suggesting that it does not accurately represent the potential of a solid and questioning its relevance to electron localization.
  • A participant emphasizes that the Bloch waves, while delocalized, form a basis for describing the wavefunction of all electrons in a metal, which is antisymmetric.
  • There is a suggestion that conduction electrons can be visualized as wave packets due to interactions with their environment, which introduces randomness to their localization.
  • Some participants challenge the notion of discussing a single electron in a metal, advocating for a multiparticle perspective that considers the collective behavior of electrons.
  • Concerns are raised about the validity of the free electron model, particularly regarding its applicability and the conditions under which it holds true.
Participants express multiple competing views regarding the localization of conduction electrons, with no consensus reached on the validity of the models discussed or the nature of electron behavior in metals.
Limitations include the potential inaccuracy of the infinite potential well model for metals, the dependence on the effective mass approximation for the free electron model, and the unresolved implications of interactions on electron localization.
JoAuSc
Let's say we use a very simple model consisting of non-interacting electrons in a 3D infinite square well, perhaps a cube of a single metal crystal. If an electron is in a particular energy state, then its wavefunction is spread across the entire crystal.
However, electrons are said to travel through conductors like particles, implying that their position is at least somewhat localized. This would imply that an electron with a somewhat well-defined position must be in a superposition of energy states whose wave functions cancel out everywhere but near the position of the electron.
So, which is it? I'm betting it's the latter one, and that the interactions between an electron and its environment act more as a measurement of its position than its energy, but I'm not sure and I'd like to hear from the experts.
I'm by no means an expert, but i'll put my 2 cents worth.
In my opinion its the former, i.e. electrons are de-localized in space (localized in momentum space). This is the only way that the notion of energy-band picture makes sense to me, along with Fermi-Dirac statistics. The electron 'moves' by changing its wavevector, i.e. in a case of infinite square well the excitation hops between the quantum number n describing the ladder of states.
Lol, I might get myself in trouble right now, but at least it hopefully will generate interesting discussion...
This makes no sense!
The potential you're describing has nothing to do with the potential of a solid, much less, a metal. So why do you think you can use that to represent a metal?
And why are you inventing such a thing for a metal? What's wrong with the periodic potential that gives you the Bloch wavefunction?
Zz.
What Zz says is definitely true -- i.e. one has to take into account crystalline lattice. However, one can think of zeroth order model of the solid is that of a potential box, corresponding to the edges of the solid. I thought the question wasn't really about that, but whether the conduction electrons (say they are in this box if that's what we agree to use as a model) are localized in space or not.
I will have to go with 'no', because of the reasons provided in my previous post.
I'm new on this forum, but I think i can 'smell' a good discussion coming...
I am not sure there was ever a infinite-potential well that has ever been used to "model" a metal. I can't recall seeing such a thing in any intro QM classes (or did I slept through it?).
Now, if one were to use the plane-wave "free" particle description to model the conduction electrons, THAT I can understand. But then, one then argues "But ZapperZ, what if we make the boundary of the infinite potential infinitely far away?"
Viola! Plane-wave free particle! So why go through the hassle of infinite potential set up?
Zz.
The free electron model is quite common thing to see in introductions to solid state physics.
The Bloch waves are as delocalized as plane waves (or as eigenstates in big box potential), so replacing plane waves (or eigenstates in big box potential) with Bloch waves does not change the original question essentially. I'll ask the original question again, this time in a form demanded by ZapperZ:
"Do the electrons exist as localized wave packets, or as delocalized Bloch waves?"
The Bloch waves just form a basis of the (relevant part of the) Hilbert space. If we had a single electron it would be in some superposition of these Bloch waves.
But it's not even correct to talk about a single electron inside a metal. There is one, multiparticle state/wavefunction describing all electrons. This wavefunction is antisymmetric with respect to all the electrons. And we use a basis of Bloch waves to describe the part of this wavefunction which is responsible for the conducting properties.
Actually, we CAN. That's the whole point of Fermi Liquid Theory.
You change a single many-body problem and transpose it to many one-body problem. In doing that, you renormalize the charge carrier into a quasiparticle whereby the many-body interaction has been simplified via a mean-field potential.
Zz.
Yes, ofcourse. But that doesn't get rid of the statistics. In the end you're still describing a completely antisymmetrized wavefunction. And not a wavefunction which is "just" a product of single-particle wavefunctions. Although you're right that this step is, in some sense, only taken at the end.
I'd like to add several remarks:
(1) It is surely not proper to model metals using infinite high well potential. Because, in this case, the electron can not be in Bloch states, which is based on translational symmetry. And thus, the electrons can not have any values of averaged velocity than zero. In other words, these electrons cannot move at all !
(2) In a real metal, I believe the conduction electrons are better visualized as wave packets. The reason is the interactons of the electron with its environment, and such interactions are random. Actually, this is exactly the picture adopted in the semi-classical theory that deals with the transportation properties of a metal (see e.g., D. Mermin)
hiyok
Zz.
Many wrong things have been stated in this thread but this particular one from Zz is a jewel. Read it over and over again, and try to absorb it EXACTLY the way Zz put it.
Very good post.
With a very big, important, impossible to miss CAVEAT.
That the free electron model could be used ONLY IF the effective mass approximation is valid and that is true only for small energies around the chemical potential.
hiyok
Wrong.
You don't definitely need Bloch waves to model conduction band electrons. Some kind of an effective mass approach is most frequently used in practical calculations.
And you can assume WHATEVER boundary condition you like (infinite well, PBC, Open, Dirichlet) AS LONG AS the boundaries are far, far away from the region you are interested in. This ensures that whatever you assume for the boundary condition DOES NOT affect the actual transport properties.
It turns out that the math is simplest when PBC (periodic bounary conditions are assumed) which gives [tex]k_x= \frac{2\pi}{L_x}[/tex] kind of periodicity ( allowing negative k-values). But you could just as well go about assuming an infinite well, and in this case
[tex]k_x = \frac{\pi}{L_x}[/tex] but this time negative k-values yield identical states and you end up with the SAME number of states you'd get if you had assumed PBC initially. This is re-assuring.
So don't get things all mixed up. Boundary conditions are completely independent of how you model the solid inside.
Inside the solid, you could choose a free-electron model (provided that you have a valid effective mass description) or you could do it exactly using the Bloch waves, but these have nothing to do with the kind of boundary condition you assume.I know what bothers people when I say you can have a particle-in-a-box and current flow in that box at the same time, because they are thinking in terms of resonant energies ,and they assume discrete energy levels. But this boils down to one of the most difficult problems in physics:
You have the simplest conductor with one single energy (ignoring spin) and you make two contacts to it. How do you model the current flow through this thing?
The answer only became clear in the last 20 years with the rise of mesoscopic physics and some theoretical acknowledgment of the importance of contacts. And the current viewpoint in the community is that when you make contacts to a BOX the levels are not really resonant energies anymore - but they broaden out in infinite range.
And energy becomes and independent variable of the electrons because you can EXCITE the box from the contacts AT ANY ENERGY.
To get more information on this you can google
Quantum Transport
nanoHUB.org
Meaning of Resistance at the Nanoscale,
etc...
Hi, sokrates,
I understand what you mean. But, actually I was not talking about the boundary conditions. I was either not talking about Bloch waves. What I really intended is that, maybe you can have many options of boundary conditions, but it is inevitable that these electrons are in delocalized states, otherwise there won't be any current and there would not be any disputes over the original post any more.
hiyok
This is a subject that I've often found confusing, as I've never been able to reconcile the semiclassical approximation that people use (e.g., the Boltzmann transport equation) with the quantum mechanical structure of a solid. That is, Bloch waves are obviously extremely delocalized, while the BTE requires that particles be localized in position and momentum space. Is it just a matter of constructing the "right" wavepacket? Is it mostly due to the decoherence that interaction with the environment provides? Or is it some combination of the two?
I believe the decoherence should be the sole cause. If one cools a metal to much low temperatures, the semiclassical picture should eventually break down.
Thank you, everyone. I didn't expect to go to physicsforums and find a month-old thread of mine with 15 replies.
Zz.
I don't doubt that an infinite square well is a bad approximation for a solid, missing behaviors such as band gaps and such, but it seems like a good way to discuss whether electrons in solids are localized and thus in a superposition of basis states, or spread out across the solid. I'm using this model since it's the first one mentioned in my solid state physics textbook (Chapter 6 in Introduction to Solid State Physics by Kittel, described as a "free electron gas".) I'm not using the Bloch waves since the sine waves of an infinite square well are much simpler.
Zz.
That's a good point. I can't imagine that the choice of boundary conditions would make that much difference, though, and it seems that a metal cube of a finite size would be more accurately described by something with boundary conditions that aren't infinitely far away.
That would only be true for eigenstates. For a superposition of, for example, the first and second energy states of the 1D infinite square well, <x> shifts back and forth.
That brings something to mind. I didn't think about how localized electrons would collide with, say, a phonon, where you start out with two incident wavevectors and end up with two different ones. A localized electron would necessarily have many wavevector components, so in a sense if it was involved in a collision, then part of its wavefunction would be reflected and the remaining part wouldn't be affected, which seems strange. Also, wavepackets spread out over time, so if an electron was indeed located in a certain region, then it'd either need to have its position measured on a regular basis, or it'd spread out.
Yeah, exactly my problem. There are large gaps in my knowledge of this sort of thing.
Thanks for reading my reply. Again, I'm not an expert, but I don't think many people on here are (not intended as an insult). So, i feel justified sharing 'my view' on your question, without fear of being wrong - afterall we're just having a scientific discussion.
The problem of electron-phonon scatter:
Back to the 'constraints' of the question, i.e. your particle(s)-in-a-box model. First off, as many have pointed out, that is not the correct way of describing the problem, but again, in the 'zeroth' order I don't see why not. Again, for discussion sake...
In such a model you get stationary solutions (i.e. standing waves). I'm talking for low enough temperatures that the modes are indeed orthogonal (If I say zero temperature, we don't have phonons). If a phonon 'comes along' (there's no lattice per se, but nonetheless), it will interact with the electron iff both momentum and energy are conserved (of course). So, if there's overlap in energy between the two (say you're interacting with acoustic phonon), the rest is conservation of momentum. Since standing wave has zero momentum I see that two phonons have to be emitted in the opposite directions (of half energy each). In that process electron would 'hop' up or down the ladder (emission versus absorption of phonon) corresponding to the gained energy.
Er... Alpha Centauri can be considered to be infinitely far away when you consider gravitational forces acting on the earth. But yet, to our galaxy, it isn't. If you are the size of Angstroms, the edge of a metal cube that is centimeters long is infinitely far away such that it doesn't matter anymore. That is why in many description of the properties of solids, the boundary condition of the surface or the edge of the material is typically insignificant. You don't see the BCS ground state accounting for the size of the superconductor, do you?
Zz.
You're arguing that for bulk solids, it physically doesn't matter whether you choose the infinite square well's sine waves or the free particle models's complex exponentials, but that using the latter is much simpler to deal with. I'll concede that, though only the ISW has a non-zero fermi energy. The Kittel text I referred to above, strangely enough, mentions the infinite square well as the model used but uses the complex exponentials in calculations.
Zz.
I'm going to have to take your word for it.
I'm probably going to get kicked out of the discussion group for this, but ZapperZ has an awful lot of nerve ridiculing you for modeling the problem with a potential well and then coming back and niggling over the boundary conditions.
Read again. Where did I "ridicule" him? I asked because I am utterly puzzled by the thought of going around the long way to get to something that could easily be reached directly. The boundary condition IS the whole issue here with regards to the situation.
Look at the BCS ground state, the Drude model, the Bloch wavefunction, etc... etc. Many of these (and quite a few of them you use as basic electric circuit laws such as Ohm's Law, etc.) simply do not CARE about such boundary conditions. This is why I queried on the whole rational of considering it in the first place. Is there some insight in imposing such boundary that gives us something that the traditional simple model doesn't do? I haven't seen such explanation yet.
So how is this ridiculing? If you think it is that, you ought to attend a lot more physics seminars, or go attend the APS March Meeting. Compare to those, what I've said here is a non-event!
Zz.
Since when straight intellectual bashing is called "ridiculing"?
If you took the time to read the entire thread, you would have seen that quite a few of us have been perpetuating the same things over and over again.
There's no such thing as modeling the problem with an infinite potential well. Dynamics -- and boundary conditions are two different things. These should not be mixed up.
You cannot just go about choosing a free electron model inside the device, unless you could be working under the conditions of the EFFECTIVE MASS theorem. This would not be an atomistic model and the wavefunction actually would be smoothed out over the lattice. But hey, you could just as well use an atomistic tight-binding model, to get the actual Bloch waves and rapidly changing wavefunctions.
These have NOTHING to do with what happens at the boundaries UNLESS you have a nanostructure where the boundaries are so close that they actually matter.
There's only one place that I know of , where you can sense a difference experimentally:
Graphene Nanoribbons (GNR) and Carbon Nanotubes (CNT):
CNT is the only material in nature that PBC (periodic boundary conditions) really exists -- and in GNR , the boundary conditions are really like that of an infinite well (because the lattice abrubtly ends) and the difference is obvious:
In GNR you see quantized conductance steps of 2 e^2/ h (quantum of conductance including spin) , and in CNT you see quantized conductance steps of 4 e^2 /h instead.
This is due to the familiar pi / a and 2*pi/a spacing of states depending on the boundary conditions I described in detail a few posts earlier.
Now the Hamiltonian of GNR and CNT is almost exactly the same - but since these are really small devices (a few atoms thick) the boundary conditions actually make a difference.
In regard to what ZapperZ is saying: I think this could be the only example where you could see that choosing a different boundary condition changes experimental facts in your device but this is due to the NANO-aspect of the problem.
This discussion on applicability of boundary conditions to this problem is amusing to me. Was I the only one that interpreted the original post to mean that this was taken as a "toy" model of a solid, i.e. a 1D box with bounding potential at zero temperature, etc... to boil the problem to the one we can solve...a zeroth order approximation to metal if you will? Sure, this is not in your standard solid-state textbook (i don't remember seeing it in kittel, but i'll take another look...) -- does that mean that it can't be discussed? APS March meetings would be so boring if to all the gedanken experiments somebody was replying - "no, sir, no can do! this is not in my solid-state book!"
Maybe this reality check can help? Consider a 'tiny' cube of metal. Momentum space is quantized along all three dimensions with some separation Dk. Now, you can make your cubes larger if you want, say expand by N in all the directions and sure enough the spacing between the modes will decrease by (1/N) and even go to zero as you go out to infinity. So, let's not be mathematicians and not talk about infinities. That leaves us with the notion that even for your cubes of 1x1x1cm piece of copper the states are separated by the corresponding Dk/N, where N is a large number. The characteristic quantity that allows one to judge the transition from quantized to continuous is the kT. So, if say DE associated with Dk is smaller than kT, then we talk about Drude... So, this corners the discussion into the realm - how large is the structure and at what temperature... errr... the whole point was to talk about basic physics without these hangups... can we get back to the essence of the question of localized versus delocalized, instead of nit-picking about the boundary conditions??
Then you have completely missed what I was asking.
I was asking for the rational reason on WHY one would want to consider such a thing, when it makes the problem so much more DIFFICULT!
We continue to teach the wave picture of light when we talk about interference and diffraction, when we KNOW for a fact that we can derive ALL of such phenomena via QM alone without invoking such wave picture (ref: Marcella). But yet, WHY do we continue to use the wave picture whenever we deal with interference and diffraction? Isn't this just MORE confusing to the student? No, because handling it via the wave picture makes it EASIER to deal with, and the outcome and results can be obtained in a more transparent manner. The QM derivation of it is so much more tedious.
So there is a pedagogical reason for continuing with the wave picture. What is the pedagogical reason for adopting the line of attack in the OP? This is what I have been asking, and this is what I haven't been given a sufficient answer to. If all we have here is "I have no idea why I would want to pursue such a thing and it just came out of thin air", then I'll shut up.
Zz.
A classical delusion of a beginner...
Just because all the zeroth order elementary QM textbooks start with the amusingly simplistic particle in a box problem to show the beginner that the levels will come out to be quantized DOES NOT mean that it is applicable to the HUGELY complicated solid structures where the picture is NOTHING like that "TOY" model.
A toy model of a solid could be a 1D nanowire, or a periodic array of atoms, or something of that sort but NOT the first thing you see in a QM textbook meant for layman.
No; I am sorry but you cannot use your "model" for this problem. Particle in a box is meant for my little brother who is a freshman... If you think you can get away with that, you are deeply mistaken. There are some problems that require at least some sane 5-minute thinking before you make a "valiant" attempt to come up with an extremely "versatile" model nobody has thought before! You can get lost in your textbooks as long as you want, EVEN Kittel in his elementary text will not do that.
I guess your "sanity check" will be amusing to the working physicist in this field.
Yes, you seem to be the only one to underestimate this extremely difficult problem with a so-called toy model that almost insults a BRANCH of physics, which by the way is the name of the forum under which you are posting, evolving for the past hundred years.
Suppose you had a 1-mm diameter wire, 1 meter long (mass 7 grams), that you used to connect to an ideal battery, and charge it at one amp for 96,000 seconds (Avagadro's number of electrons). You now disconnect the battery and put it in your pocket. Where did all the electrons come from (Did they come from the wire, or somewhere else)? (You charged it with about 25% of ALL the electrons in the wire). What happened to the electrons' wave functions when you put the battery in your pocket?
sokrates said:
No; I am sorry but you cannot use your "model" for this problem. Particle in a box is meant for my little brother who is a freshman... If you think you can get away with that, you are deeply mistaken. There are some problems that require at least some sane 5-minute thinking before you make a "valiant" attempt to come up with an extremely "versatile" model nobody has thought before...
Actually, I thought it was quite a good model to choose for the problem posed by the OP: namely, whether electrons in a metal are localized. The simple model of a potential well would seem to potentially offer some useful insights on this question. I haven't seen any of the naysayers offer any explanation as to why it might be inadequate.
Er... derive Ohm's law out of it, for example!
Furthermore, how is it possible to know that a model that doesn't offer any result that matches observation, is somehow a valid model to a particular system? How are you to know that an arbitrary model that was picked is a valid model to offer a "useful insight" on the locality of electrons in a metal?
Zz.
The more i think about it the more i come to realization that it's in fact the most correct (from theoretical standpoint) model to describe the problem, of course with the caviat that the lattice is missing.
So, if we turn on the lattice we have the translational periodicity that would be reflected in the wavefunctions, modifying them to Bloch states. Then one sees that dispersion relation for small values of quasi-momentum (k) stays parabolic-like (allowing you to treat the electrons as nearly-free (with renormalized mass)). For large enough k's you run into Bragg scattering with the lattice periodicity, -- the notion of a bandgap. So where are the boundary conditions of the solid come in, i.e. that infinite-square well potential, our 'zeroth' order model? Well, it comes in the fact that the dispersion relation is not continuous, but consists of discrete values of k (much much smaller than pi/a, say epsilon), where a is the lattice periodicity). These discrete values are nontheless there, where you want it or not. Of course at finite temperature (when kT > epsilon^2/2m), this discretization is washed out by the thermal fluctuations.
So, if we either lower the temperature enough for kT to be comparable to epsilon^2/2m, or if we reduce the size of the box, we will notice the effect of boundary conditions on the problem. In what sense? In the sense that we no longer have Drude-like picture, but electrons have discrete energy values, so putting restrictions on what scattering processes can occur and hence modifying all the macroscopic observables - conductivity for example. Another way of saying this is that we will form sub-bands within say valence bands, i.e. mini-bandgaps.
So, what I'm saying is that if you insist to treat the problem from jellium model perspective, go ahead, but if you want to recover proper physics either at smaller dimensions or lower temperature than boundary conditions are very important.
I still haven't seen any opponents offer any answers to the original question of the post: localized versus delocalized states.
BTW, i might be totally dillusional about this due to the fact that I'm a beginner, but isn't that the point of this forum is to share your expertise with others so they can learn from you instead of petting your own ego by putting everybody down? If i want to deal with ego problems i can go talk to professors... or wait... maybe you're one of them? :-p
  • · Replies 0 ·
  • · Replies 0 ·
