Thread Closed
alternate form of the quadratic formula
Share Thread Thread Tools
Jun5-09, 03:55 PM   #18
I remember there was one way where if b is divisible by 2, you can use a simpler formula but I forgot what it was...
like when ax2+bx+c=0; b is divisible by 2
I might be wrong though : )
Jun5-09, 04:57 PM   #19
gel
Also, to get the alternate form, divide ax2+bx+c = 0 by x2 to get a + b(1/x) + c(1/x)2=0. This is just a quadratic in 1/x with a and c switched around. So, you can switch a and c in the standard quadratic formula to solve for (1/x) and then switch numerator and denominator to get the alternate form for x.
Jun5-09, 06:46 PM   #20
D H
Mentor
Quote by Imparcticle View Post
why doesn't the computer run them the same?
Computers typically work in base 2. For the point of illustration, assume you are working with a computer that uses base 10 for floating point arithmetic and assume it only has 5 significant digits. For example, computing 1.0/3.0 and 200.0/3.0 on this computer yields 0.33333 and 66.667, respectively. Now suppose you need to find the solutions to
[tex]x^2-315x+1=0[/tex]
You apply the simple version of the quadratic formula:
[tex]x=\frac{315\pm\sqrt{315^2-4}}2 = \frac{315\pm\sqrt{99221}}2[/tex]
On this computer, [itex]\surd 99221 = 314.99[/tex] (the correct answer: [itex]314.993651\cdots[/itex]. The two solutions as calculated on this computer are
[tex]\aligned
x_1 &= \frac{315-314.99}2 = 0.005 \\
x_2 &= \frac{315+314.99}2 = 315.00
\aligned[/tex]
The correct values are [itex]0.00317463517\cdots[/itex] and [itex]314.996825\cdots[/itex]. The larger of the two values is correct to five decimal places. The smaller of the two has zero significant digits. Now look what happens when you calculate the smaller value using the alternate form:
[tex]x_1 = \frac 2{315+314.99} = 0.0031747[/tex]
which is correct to four significant digits.
Sep28-10, 08:12 AM   #21
Why does the accuracy become better when we move the arithmethics to the divisor ?
Thread Closed
Thread Tools
Similar Threads for: alternate form of the quadratic formula
Thread Forum Replies
simplify to quadratic form General Math 6
Quadratic in standard form help....please Precalculus Mathematics Homework 5
reduction of quadratic form (principal axis) Calculus & Beyond Homework 4
Quadratic Form Calculus & Beyond Homework 3
