| Thread Closed |
Path difference and phase difference. |
Share Thread | Thread Tools |
| Jun14-04, 06:13 AM | #1 |
Pardon the pun, but what's the difference between path difference and phase difference (when talking about interfering light waves)?
| Jun14-04, 06:34 AM | #2 |
Path difference is the distance one wave (from a coherent source) has to travel from its source to the observer. ie one observers ear may recieve the crest and the other ear recieve the trough. this would give a path difference of 1/2 wavelength.
Phase difference is best understood by considering a cosine wave and a sine wave. they are 90degrees out of 'synch' with each other and would produce destructive interference. i hope someone with more brains than me can clarify your quandary. I think i am corect but i am sure someone here can be more specific. |
| Apr16-08, 01:46 PM | #3 |
| Apr17-08, 07:58 AM | #4 |
Recognitions:
As a beam traverses space, the phase of a ray goes as [tex]\phi (z) = k n z [/tex], where k is the wavevector, n the refractive index, and z the distance. The quantity nz (or nd, where d is the thickness of an object) is referred to as the optical thickness. It's easy to make the sitation more complicated- make the refractive index vary with location, for example. Or make it vary with wavelength. Then the phase delay *relative to another ray*, which is the important thing, is given by more complex versions of the above formula.
Even so, there is no difference between path and phase difference, when you are able to sensibly speak of rays. This is not always the case- strongly focused light, for example. Simply considering polarization can create difficulties, forcing you to keep track of the propogation axes by hand. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Path difference and phase difference.
| difference between phase difference and path difference | General Physics | 5 | ||
| Phase shift from path difference | Advanced Physics Homework | 0 | ||
| Phase shifted waves due to path difference | Introductory Physics Homework | 0 | ||
| Waves-Path and Phase Difference Relationship | Introductory Physics Homework | 8 | ||
| What is path length difference? | Classical Physics | 2 | ||
