Solve Heat Exchange Problem: Steel from 25°C to 60°C
The discussion focuses on calculating the heating and cooling times for a block of steel using oil and water in a heat exchange scenario. The steel block dimensions are 230mm x 230mm x 40mm with a density of 0.00785 g/mm³. The oil, heated to 180°C, has a flow rate of 1.66 L/sec, while the water, at 15°C, has a flow rate of 2.46 L/sec. The calculations indicate that it would take approximately 0.76 seconds to heat the steel from 25°C to 110°C using oil, raising concerns about the feasibility of achieving such rapid heating in practice.
  • Understanding of heat transfer principles, specifically in heat exchangers.
  • Familiarity with specific heat capacity (S.H.C.) calculations.
  • Knowledge of fluid dynamics, including flow rate and velocity calculations.
  • Basic proficiency in unit conversions, particularly between metric and imperial systems.
  • Research the principles of heat exchangers and their efficiency in heating and cooling applications.
  • Learn about specific heat capacity calculations and their implications in thermal systems.
  • Explore fluid dynamics concepts, focusing on flow rate and pressure drop in pipes.
  • Investigate practical limitations and considerations in real-world heat exchange scenarios.
Mechanical engineers, thermal system designers, and students studying heat transfer and fluid dynamics will benefit from this discussion.
alex0919
A block of steel dimension is 230mm*230mm*40mm=2,116,000cubic millimeters
0.00785 gram/cubic millimeters is the given steel density
Using 180 degree celsius oil (density given is 0.9) to heat up the steel from 25 degree celsius to 110 degree celsius in a 10mm diameter and 428.5mm long channel with oil pressure at 10 bar from the inlet. How long will it take to heat up the steel to the target temperature? What's the oil flow rate?
Then
Using 15 degree celsius water (density given is 1) to cool down the steel from 110 degree celsius to 60 degree celsius in a 8mm diameter and 489.5mm long channel with water pressure at 10 bar from the inlet. How long will it take to cool down the steel tempeerature to 60 degree celsius? What's the water flow rate?
Known S.H.C. of steel is 0.112 Kcal/Kg/per celsius degree
oil is 0.5 Kcal/Kg/per celsius degree
Water is 1 Kcal/Kg/Per celsius degree
1atm = 14.7psi =101,325Pa
1kg/cm^2 =14.2psi= 97,878.57Pa
2kg/cm^2 =195,757Pa
10kg/cm^2 =978,785Pa
u^2 = 978,785/1,000
u^2/gc = P/d
gc=1
u = 31.29 m/s (Water with density of 1)
u = 32.98 m/s (Oil with density of 0.9)
Oil flow rate=32.98m/sec*3.14*0.004m*0.004m=0.001657cubic meters/sec=1.66 Liter/sec.
Water flow rate=31.29m/sec*3.14*0.005m*0.005m=0.002456cubic meters/sec=2.46Liter/sec.
Is my calculation on the velocity right? It looks to me there is something wrong compare with the result we got in a practice similar to this.
(110-25)*0.112*16.61Kg(steel weight)=158.1272Kcal
(180-110)*0.5=140Kcal
158.1272/140=1.12948Kg of required Oil /0.9(Oil density)=1.2550 Liter
1.2550Liter/Oil flow rate at 1.66L/Sec=0.76 sec.
I am not quite sure if my calculation is right because practically, I don't think we can achieve the target in that short period of time. I think there must me something wrong on my calculation. Can anybody point out my mistake? Thank You!
Hi alex, welcome to PF.
Just as a pointer when posting homework questions you should always point out where you need help so that people may help you. Simply posting the question and calculating an answer means you posted the question and calculated an answer...nothing else.
thanks! I had added more detail.
  • · Replies 56 ·
