Any idea about how determine body movement upun the accelerations?
  • Context: Graduate
  • Thread starter Thread starter niko2000
    Body Idea Movement
The discussion focuses on determining body movement based on acceleration measurements obtained from accelerometer sensors. Participants explore methods for analyzing acceleration data to classify types of movement, such as walking, running, or falling, with an application aimed at automatic emergency detection for individuals who may fall.
  • Exploratory, Technical explanation, Debate/contested
  • One participant, Niko, seeks to implement an algorithm to analyze acceleration data to automatically detect different types of movement, particularly falls.
  • Another participant suggests that the x, y, and z components of acceleration can be treated separately and discusses the need for numerical integration of the data to determine speed and position over time.
  • A subsequent reply emphasizes that numerical integration is manageable and recommends the Runge-Kutta 4 (RK4) method as a stable numerical integrator.
  • Another participant questions how to determine the type of motion solely by integrating the graph of acceleration data and references a related concept discussed in a personal blog.
Participants generally agree on the need for numerical integration to analyze acceleration data, but there is no consensus on the specific methods or approaches for accurately determining the type of movement from the integrated data.
Limitations include the potential variability in acceleration data and the assumptions made regarding initial conditions for speed and position. The effectiveness of different integration methods in this context remains unresolved.
niko2000
Any idea about how determine body movement upon the accelerations?
Hi,
I am trying to implement an algorithm which would determine the person's activity upon the received acceleration measurement data.
I am measuring the accelerations using accelerometer sensors on mobile phones and send the data to the server where I process the measurement and try to determine the type of person's movement. The key idea is to develop the software which would automatically call the emergency if the person would fall (useful for old people).
So far I was trying to use Fourier transform and measure the frequency components but this by itself is not accurate enough. Enclosed I am sending an example chart of walk.
In case of fall it is easy to guess what happened by watching the chart but the goal is to implement an automatic detection.
I would really appreciate if you could share your idea about analyzing the patterns and determine what happened. It would be great if a computer could determine for example if the person is walking, running or if a person fell.
Thanks for help!
Niko
First, the good news- you can treat the x, y, and z components separately.
Now, the bad news- if your acceleration data is not constant, you will need to do a numerical integration of the data.
Given a(t) as the acceleration for a particular component, [itex]v(t)= \int_{T_0}^T a(t)dt+ v_0)[/itex] is the speed at time T in that direction assuming speed v0 at time T0 in that direction.
[itex]p(t)= \int_{T_0}^T v(t)dt+ p_0[/itex] is the component of position itself at time T given component p0 at time T0.
The bad news is hardly bad :) Numerical integration of data is relatively easy. For a relatively accurate and stable numerical integrator, look up Runge-Kutta 4 (RK4) which is a forth-order numerical integrator
How can you determine the type of motion by integrating the graph?
The goal is to determine the type of movement by analizing graph - whether it is walk, run, fall...
I wrote about the concept here: http://mypetprojects.blogspot.com/
  • · Replies 33 ·
  • · Replies 78 ·
