| Thread Closed |
Is there a difference between "mean speed " and "average speed"? |
Share Thread | Thread Tools |
| Apr25-09, 12:16 PM | #1 |
Is there a difference between mean speed and average speed? The words "mean" and "average" seem to mean the same thing.
| PhysOrg.com |
physics news on PhysOrg.com >> Promising doped zirconia >> New X-ray method shows how frog embryos could help thwart disease >> Bringing life into focus |
| Apr25-09, 12:20 PM | #2 |
Mentor
The words are the same.
| Apr25-09, 07:43 PM | #3 |
Recognitions:
You may be thinking of "median" which is different. Assuming a "sample" rate based on time, over some fixed time interval, it woudl be the speed at which 1/2 the time in the interval was spent below or at the speed and the other have above or at the speed. Median is more useful in statitics where the samples are discrete and not continuous.
| Apr26-09, 12:50 AM | #4 |
Is there a difference between "mean speed " and "average speed"?I was told that mean speed is (v+u)/2 (v is final velocity and u is initial) while average speed is simply distance/time |
| Apr26-09, 04:51 AM | #5 |
| Apr26-09, 05:09 AM | #6 |
Thats some good observation on your part, I never noticed that Americans tend to use avg. and Brits use mean. I just read avg and mean as one and the same.
I suppose its technically less ambiguous to use mean. in reality everyone knows what you are on about anyway "Take the average speed" "Erm which average? mean median or mode" |
| Apr26-09, 05:35 AM | #7 |
Mentor
Er... hello?
If "mean velocity" is defined as (v+u)/2, while average velocity is the total distanced traveled over time, then they are NOT identical, and it is no longer simply "Americans versus British" usage! The definition of "mean velocity" is very strange, unless it is for a very specific situation of a uniform, constant acceleration. I would tend to go with Russ and say that they are the same thing, and that this "definition" here needs to be looked at more carefully to see if it is valid. Zz. |
| Apr26-09, 05:42 AM | #8 |
| Apr26-09, 06:03 AM | #9 |
Recognitions:
There's also "mean" as in "mean value theorem", where the mean point is the point at which the tangent to the curve has the same slope as the slope from start point to end point. In the case of constant acceleration, velocity versus time is a straight line, and the mean value could be any point on the line, so it doesn't mean much in that case (I know bad pun). |
| Apr26-09, 08:21 AM | #10 |
Good point. I've always used them interchangably without a second thought about the situation. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Is there a difference between "mean speed " and "average speed"?
| Difference between "Identical", "Equal", "Equivalent" | Calculus & Beyond Homework | 9 | ||
| What is the difference between "induced" and "influenced" ? | Classical Physics | 1 | ||
| Difference between "Traction" and "Tractive Force"? | General Physics | 2 | ||
