Circular motion?
by brentwoodbc
Tags: circular, motion
brentwoodbc
brentwoodbc is offline
#1
Apr25-09, 02:32 PM
P: 62
a test tube rotates in a centrifuge with a period of 1.2x10^-3s. The bottom of the test tube travels in a circular path of radius .15 m. with the centripetal force on a 2.00x10^-8kg amoeba at the bottom of the tube.
3. The attempt at a solution
ac=v^2/r=(4pi^2r)/T
cross multiplied and got.
v^2x(1.2x10^-3)=4pi^2x(1.5^2)
divided
and solved for velocity and I got.
V=27.21
then fc=(m2v^2)/r
fc=(2x10^-8)x(27.210^2)/.15
fc=9.87x10^5????
supposed to be 8.22x10^2
THanks.
Phys.Org News Partner Science news on Phys.org
Lemurs match scent of a friend to sound of her voice
Repeated self-healing now possible in composite materials
'Heartbleed' fix may slow Web performance
Doc Al
Doc Al is online now
#2
Apr25-09, 05:31 PM
Mentor
Doc Al's Avatar
P: 40,872
Quote Quote by brentwoodbc View Post
ac=v^2/r=(4pi^2r)/T
divided
V=27.21
Two problems:
(1) That equation is not quite right. The right hand side should be: (4pi^2r)/(T^2)
(2) Why did you solve for V? What you want is v^2/r, which is given directly by the (corrected) right hand side.
MalachiK
MalachiK is offline
#3
Apr25-09, 05:32 PM
MalachiK's Avatar
P: 112
It's not clear what the question is asking.
If you're looking for the force then you could start by finding the linear velocity. Just think distance divided by time and the circumference of the circle that the end of the tube is moving along.
You have a formula for the acceleration in terms of v and r. Compare this to Newton's second law and you should be able to get the accelerating (centripetal) force in terms of v and r as well.
LowlyPion
LowlyPion is offline
#4
Apr25-09, 05:36 PM
HW Helper
P: 5,346
Circular motion?
ac=v^2/r=(4pi^2r)/T
divided
V=27.21
then fc=(m2v^2)/r
fc=9.87x10^5????
THanks.
Or more directly for the same result
F = m*ω2*r
where ω = 2π/T
F = m*(2π/T)2*r
Edit: I think the correct answer should have a (-) exponent ?
brentwoodbc
#5
Apr25-09, 05:57 PM
P: 62
Quote Quote by Doc Al View Post
Two problems:
Thanks
You are correct, The T^2 was my mistake. I have the right answer now (8.22 x 10^-2)
I do not understand what you mean by just using the right side?
ac=(4pi^2r)/T
there's no v there.
I solved for v to use the formula fc = (m2v^2)/r
Doc Al
#6
Apr25-09, 06:05 PM
Mentor
Doc Al's Avatar
P: 40,872
Thanks
I didn't check your calculation. Was it just a typo?
ac=(4pi^2r)/T
there's no v there.
You started with the equation: ac=v^2/r=(4pi^2r)/T^2
What you need (to move to the next step) is v^2/r, which equals (4pi^2r)/T^2. You don't need to know V explicitly:
thus:
Fc = mac = mv^2/r= m(4pi^2r)/T^2
You could go right to the answer using only r and T, which were given.
brentwoodbc
#7
Apr25-09, 07:31 PM
P: 62
thus:
Oh in the sense f=ma. that makes sense.
Thank you.
Register to reply
Related Discussions
Simple Harmonic Motion- From Uniform Circular Motion Introductory Physics Homework 5
Uniform Circular Motion, Rotational Motion, Torque, and Inertia General Physics 1
Question on relative motion and circular motion. Introductory Physics Homework 6
when to use term Rotational motion and Circular motion? General Physics 2
Motion in a Plane question dealing with circular motion Introductory Physics Homework 11
