Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
image Complex Engineering Puzzle!!! Share It Thread Tools Search this Thread image
Old Apr26-09, 10:23 PM                  #1
reinaldo
reinaldo is Offline:
Distribute 20 lbs of pressure in 5 hours, the numbers Must be Odds and each hour must have a value; you cant use even numbers, nor frations, just positives completes!!
wich are the values??
Old Apr26-09, 11:38 PM                  #2
Danger
Danger's Avatar
Danger is Offline:
Recognitions:
PF Contributor PF Contributor
Re: Complex Engineering Puzzle!!!
I'm sorry, dude, but that question doesn't really make any sense as presented. Can you express it a bit more accurately?
Old Apr27-09, 12:05 AM                  #3
NBAJam100
NBAJam100 is Offline:
errr wouldnt one of the numbers have to be zero for this to work?? otherwise you would always get at least one even number... right?
Old Apr27-09, 04:26 AM                  #4
jimmysnyder
jimmysnyder is Offline:
There is not one single answer, but here is one possible answer:
Spoiler
midnight - 1
1 0'clock - 1
2 0'clock - 1
3 0'clock - 1
4 0'clock - 1
5 0'clock - 15
That's an odd number at each hour, and 20 in 5 hours.
NBAJam100, zero is an even number.
Old Apr27-09, 12:15 PM                  #5
junglebeast
junglebeast is Offline:
jimmy,
your solution takes 6 hours (rounding up). There is no solution to this question for 5 hours.
Old Apr27-09, 01:22 PM       Last edited by davee123; Apr27-09 at 01:32 PM..            #6
davee123
davee123 is Offline:
You could wait until daylight savings to switch, then 5 hours magically becomes 4 or 6, and you're golden.
Technically, Jimmy's takes 5 hours, not 6 hours, it's just that it doesn't take up a full hour. So he's assuming (for example):
12:30:00 - 1
1:30:00 - 1
2:30:00 - 1
3:30:00 - 1
4:30:00 - 1
5:29:59 - 15
Hence, the "hour" of midnight has 1 in it, and the "hour" of 1 has 1 in it, etc. At least, that's my understanding of his answer.
DaveE
Old Apr27-09, 02:11 PM                  #7
jimmysnyder
Originally Posted by junglebeast View Post
jimmy,
Round down.
Old Apr27-09, 02:15 PM                  #8
jimmysnyder
12:30:00 - 1
1:30:00 - 1
2:30:00 - 1
3:30:00 - 1
4:30:00 - 1
5:29:59 - 15
DaveE
Your solution takes 4 hours, 59 minutes and 59 seconds. Mine takes 5 hours.
Old Apr27-09, 02:37 PM                  #9
davee123
That gets into the discussion of whether or not you can measure an infinitesemal unit of time, of course-- I was just going by the "normal" measure of time which is to say that since the majority of the full second at 5:30:00 lies AFTER the 5 hour mark, you usually measure the hour to the tail end of the preceeding second. Sort of like why 12:00:00 is PM instead of AM or just "M". The time between the instant it hits 12:00:00 and the instant it hits 12:00:01 is for all intents and purposes 100% (immeasurably smaller) in PM rather than "M", and hence is considered "PM".
But that's just semantics.
DaveE
Old Apr27-09, 02:38 PM                  #10
junglebeast
Round down.
The problem specifies that you must do it in 5 hours. Your solution is over the range of [0,5] which takes more than 5 hours, and is therefore an invalid solution. You need a solution that is in the range (0,5) or (0,5] or [0,5).
Old Apr27-09, 02:47 PM                  #11
davee123
It's not actually taking more than 5 hours-- it's taking *exactly* 5 hours (rounding up or down will yield the same result), and is assuming something that's physically impossible, but mathematically correct. If you imagine a square aligned in the XY plane, for instance, with 1 corner at the origin, and side lengths of 5, the corner on the Y axis isn't at 0,4.9999...., it's at 0,5. So he's basically assuming you can distribute it instantaneously.
DaveE
Old Apr27-09, 02:47 PM                  #12
NBAJam100
good point... hahaha
Old Apr27-09, 03:37 PM                  #13
jimmysnyder
The length of (0,5), (0,5], [0,5) and [0,5] were all 5 when I went to school.
Old Apr28-09, 11:26 AM                  #14
LAF
LAF is Offline:
There must be a value each hour. But maybe a value anytime. So, it΄s easy...
image image
Reply
Thread Tools
Similar Threads for: Complex Engineering Puzzle!!!
Thread Thread Starter Forum Replies Last Post
Complex Mathematical Puzzle!!! reinaldo Calculus & Beyond 4 Apr27-09 01:01 AM
Fundamentals of Complex Analysis With Applications to Engineering and Science CRGreathouse Calculus & Beyond 2 Jan13-09 04:05 PM
Civil Engineering with specialization in aviation or Aerospace Engineering Kyouran Academic Guidance 1 Feb27-08 05:50 PM
Advice on complex analysis, Riemann surface & complex mappings. Shaun Culver Topology & Geometry 3 Feb4-08 09:56 PM
Application of complex numbers in Engineering? AndreJ General Engineering 1 Mar4-07 09:29 AM
Powered by vBulletin Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
