Thread Closed
FEM/FEA Torque Wrench
Share Thread
Apr29-09, 04:54 AM   #1
Hope this is the right place for this?
I have a torque wrench, and need to calculate several parameters.
I need to calculate
- Stress
- Displacement
and
- Force required to reflect the torque rang (2NM - 30NM)
I have ansys (fea) and mathcad (fem) at my disposal to do these calculations, i am just not 100% sure on where to start?
I have done a free-body diagram, and decided that there should be 3.D.O.F, but not sure if there should only be 2?
BUT
My main problem is, how do i model a torque wrench in Ansys? I have the geomotry all sorted (i think) but i dont know how one should constrain, or even what set-up should be used? I was thinking of static structure?
Help and a push in the right direction would be most helpful, and i would be most greatful.
PhysOrg.com science news on PhysOrg.com
>> New language discovery reveals linguistic insights
>> US official: Solar plane to help ground energy use (Update)
>> Four microphones, computer algorithm enough to produce 3-D model of simple, convex room
Apr29-09, 06:40 AM   #2
There are different kinds of torque wrenches, so one answer doesn't fit all. Let's assume you're doing the inexpensive beam wrench you might buy at Sears for example.
http://www.sears.com/shc/s/p_10153_1...0070921x00003a
You can make a very quick, fairly accurate calculation using simple beam equations by hand. If you want to do a full-blown FEA on this, I'd suggest modelling it in something like Pro-E and running ANSYS. The simplifications you need to make are to fully constrain the drive end (probably 1/2") and apply a simple perpendicular force to the handle somewhere beyond the dial. The critical parameter in your design will be the deflection.
May4-09, 05:41 AM   #3
Thanks for that, will give it a go.
I am going to use ANSYS, and i think i can model the geometry in workbench so to eliminate pro/e as its a pain.
Thread Closed
Similar discussions for: FEM/FEA Torque Wrench
Thread Forum Replies
Torque on Wrench Introductory Physics Homework 3
torque wrench Mechanical Engineering 2
Another reduction to Wrench Introductory Physics Homework 2
astronaut and wrench Introductory Physics Homework 4
torque wrench Introductory Physics Homework 0
