| Thread Closed |
Figuring power dissipation increase w/ heatsink |
Share Thread | Thread Tools |
| Apr29-09, 10:01 PM | #1 |
Hello!
I'm trying to make sense of what is probably simple. Imagine I have an IC package that is rated to dissipate at most 1 Watt. The thermal resistance from case to ambient is not known (could maybe be generalized). I have a heatsink that has a thermal resistance of 20°C/W. Can I estimate what the new power dissipation of this package is? I've looked at the wiki page on thermal resistance and it compares a source of power to a current source, a temperature differential to a voltage differential, and thermal resistance to a resistor. That analogy confuses me in this scenario however, because wouldn't adding a heat sink put another thermal resistance in series with the junction-case resistance, thus increasing the overall thermal resistance of the system?!? |
| Apr30-09, 01:46 AM | #2 |
Mentor
You are correct. Thermal resistances add in series. Wikipedia.org is helpful for some things, but can be confusing (and wrong) sometimes.
You would add Theta(junction-to-case) plus Theta(case-to-ambient via heatsink) to get your total Theta(junction-to-ambient), in general. |
| Apr30-09, 05:43 AM | #3 |
Mentor
Note that the power dissipated doesn't change, just the temperature gradient.
| Apr30-09, 09:06 PM | #4 |
Mentor
Figuring power dissipation increase w/ heatsinkQuiz Question for the Original Poster (OP) -- Why not? Does it matter if the semiconductor device is a bipolar transistor versus a MOSFET? Does the circuit topology matter? |
| Apr30-09, 09:29 PM | #5 |
Mentor
| Apr30-09, 10:35 PM | #6 |
Mentor
If the sinked transistor is supplying the current for the load, and the load stays constant while the efficiency of the supplying transistor varies with temperature, then the power dissipated by the supply plus load vaies with the sinking thermal resistance. That efficiency has opposite temperature coefficients for bipolar versus MOSFET transistors.
If the "load" is everything, then your comment is still correct, I think. But if the load is being supplied by a transistor on a heat sink, then the total power consumed depends on the heat sink and type of transistor (slightly). Different Quiz Question for anybody -- how can you tell qualitatively when a heat sink is sized correctly? |
| May1-09, 09:05 AM | #7 |
| May1-09, 12:10 PM | #8 |
Mentor
I did not know that their efficiency varied with temperature - how much/over what temparature range?
| May1-09, 08:18 PM | #9 |
Mentor
Pretty small effects, but they do enter into sizing and margin calculations for circuit power calculations. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Figuring power dissipation increase w/ heatsink
| Dissipation of Power by Resistors | Introductory Physics Homework | 3 | ||
| power dissipation | Introductory Physics Homework | 3 | ||
| change in power dissipation | Advanced Physics Homework | 7 | ||
| Power dissipation | Introductory Physics Homework | 1 | ||
| Power Dissipation | Introductory Physics Homework | 1 | ||
