Thread Closed
Spin of planets, bigger means faster?
Share Thread Thread Tools
Apr30-09, 04:35 PM   #1
Quick question, do bigger planet spin faster?
PhysOrg.com
PhysOrg
astronomy news on PhysOrg.com
>> Galaxy's Ring of Fire
>> South Africa's new radio telescope reveals giant outbursts from binary star system
>> Researchers find winds on Uranus and Neptune confined to thin atmosphere layer
Apr30-09, 05:51 PM   #2
Recognitions:
Gold Membership Gold Member
Look up the data.
Apr30-09, 10:16 PM   #3
Recognitions:
Quote by valdar View Post
In general, I don't think there's any relation.
May1-09, 12:00 AM   #4
Recognitions:
You must look at planet formation to understand this issue. The short answer is yes.
May1-09, 04:25 PM   #5
I always thought that the smaller planets would rotate more rapidly than larger ones, under identical conditions of course. Much like a figure skater draws in his or her figure and seemingly rotates faster. However, I may be (and more than likely) am wrong. If someone could address this I would be interested to learn
May1-09, 04:33 PM   #6
Recognitions:
Homework Helper Homework Help
Planet Speed at equator (km/h)
Mercury 10.9
Venus 6.5
Earth 1670
Mars 867
Jupiter 45600
Saturn 37000
Uranus 10900
Neptune 8460
Pluto 47
You would expect small planets to spin faster - from conservation of angular momentum
But larger planets were formed from larger clouds of stuff.
As stuff contracted, then because of conservation of angular momentum it speeded up, the bigger/faster the original cloud the faster it ended up. Of course if you took the existing planets and made each of them smaller - they would speed up even more.
Then there are effects that have happened since. Mercury's rotation is slowed by tidal friction with the sun so has a very slow speed (long day), the Earth's is slowed a little by friction with the moon.
Uranus probably got hit by something in the past - which is why it has a weird axis tilt.
Mars might also have been affected by whatever caused the asteroid belt.
May1-09, 04:38 PM   #7
Quote by mgb_phys View Post
Mercury 10.9
Venus 6.5
Earth 1670
Mars 867
Jupiter 45600
Saturn 37000
Uranus 10900
Neptune 8460
Pluto 47
Very interesting. Thank you for providing this
May2-09, 02:49 AM   #8
A good way of comparing spin in stars is to compare angular momentum and mass in geometric units where-
[tex]a=J/mc[/tex]
[tex]M=Gm/c^2[/tex]
where
[tex]J=vmr\,k[/tex]
where [itex]a[/itex] is the spin parameter in metres, v is the equatorial rotation velocity, m is mass, r is the equatorial radius and k is the moment of inertia coefficient (0.4 for an idealized sphere of uniform density).
a/M produces a unitless figure between 0 and 1, the higher the number, the higher the spin. For the Sun (k=0.06), a/M=~0.188, for a 2.2 sol neutron star with a frequency of 1500 Hz (k=0.35), a/M=~0.488.
This doesn't appear so straightforward with planets as M works out considerably smaller than [itex]a[/itex] but there should still be a way of comparing spin geometrically.
EDIT:
In the case of planets, you could probably get away with just considering the results of [itex]a[/itex] which is considered to be the amount of angular momentum per unit of mass (sometimes expressed as J/M). In this case, Jupiter is the clear winner and Mercury has the least 'spin' per unit of mass.
Thread Closed
Thread Tools
Similar Threads for: Spin of planets, bigger means faster?
Thread Forum Replies
why the universe is expanding faster and faster Cosmology 49
Bigger wheels accelarate faster? Classical Physics 5
Does the middle of the Earth spin faster than the outer part? Introductory Physics Homework 1
Why do the planets spin ? General Physics 0
Why do the planets spin ? General Astronomy 4
