Is Griffiths' Statement About the Addition of Angular Momentum Always Correct?
The discussion revolves around the interpretation of Griffiths' statement regarding the addition of angular momentum, specifically whether the number of possible states before and after the addition of spins should always be the same. Participants explore this concept through examples involving spin 1/2 and spin 1 particles, questioning the implications of Griffiths' assertion.
  • Norm expresses confusion about Griffiths' implication that the number of states should remain constant before and after the addition of spins, suggesting that this may not hold true for particles with different spins.
  • Norm provides a counterexample involving a spin 1/2 and a spin 1 particle, arguing that there are 5 states before addition and 6 states after, which contradicts Griffiths' assertion.
  • Reilly agrees with Norm's calculation of states for the spin 1/2 and spin 1 particles, stating that there are indeed 6 states resulting from their combination.
  • Reilly emphasizes the rule for counting states when combining angular momentum, indicating that the number of states must be independent of the representation used.
  • Another participant reiterates that the spin space of the two particles is a direct product of their respective spin spaces, supporting Reilly's point about counting states correctly.
Participants do not reach a consensus on Griffiths' statement. While some agree on the calculation of states, there is disagreement on the interpretation of Griffiths' implication regarding the constancy of the number of states before and after addition.
Participants highlight the importance of correctly applying the rules for counting states in quantum mechanics, but there are unresolved questions about the implications of Griffiths' statement and its applicability to different scenarios.
Norman
I am working through some old particle physics notes of mine and when reading Griffiths "Introduction to Elementary Particles" I stumbled across a very perplexing problem:
Problem 4.9, pg 138:
"When you are adding angular momentum... it is useful to check your results by counting the number of states before and after the addition. For instance in Example 4.1 we had two quarks to begin with, each would have [itex]m_s=+\frac{1}{2}[/itex] or [itex]m_s=-\frac{1}{2}[/itex] so there were four possibilities in all. After adding the spins, we had one combination with spin one (hence [itex]m_s=1,0,-1[/itex] ) and one with spin 0 ([itex]m_s=0[/itex] )-- again, four states in all."
Griffiths seems to imply that you should always have the same number of possible states before and after addition of their spins. I am fairly confident this is wrong. But it seems so odd that such a horribly incorrect statement would be published.
My counter example to Griffiths counting argument:
addition of Spin 1/2 and Spin 1 particles:
Before the addition there are 5 possible states, 2 from the Spin 1/2 and 3 from Spin 1.
i.e.:
[tex]S_1=\frac{1}{2}, m_{s,1}=+\frac{1}{2}, -\frac{1}{2}[/tex]
[tex]S_2=1, m_{s,2}=1,0,-1[/tex]
After addition, the total spin would either be 1/2 or 3/2, with two states coming from the 1/2 state again but now four states coming from the 3/2 total spin state. This is a total of 6 final states.
i.e.:
[tex]S=\frac{1}{2}, m_{s}=+\frac{1}{2}, -\frac{1}{2}[/tex]
and
[tex]S=\frac{3}{2}, m_{s}=+\frac{3}{2}, +\frac{1}{2}, -\frac{1}{2}, -\frac{3}{2}[/tex]
Am I wrong here? Or did I just mis-understand the implication of the problem. I know he did not out right state it, but I think it is clearly implied in the problem. I believe the argument only holds when you add the angular momentum of particles with the same angular momentum. i.e. 3 quarks or 2 mediators (spin 1), etc.
Thanks,
Norm
With a spin 1/2 state and a spin 1 state there are 6 states. Three have 1/2 spin up with each of the three spin 1 states. The other three come from spin -1/2 and the various spin 1 states. This follows from the fact that state vectors for two independent systems are product states -- you count unique combinations.
Regards,
Reilly Atkinson
Regards,
Reilly Atkinson
Reilly,
I guess I don't understand your comment. Griffiths (I think) is saying you need to count the number of possible states before and after you make the addition. Are you talking about before you add them, or after? Because before you add them, you only have 5 possible values of the z component of spin- 2 from spin 1/2 and 3 from spin 1.
Cheers,
Norman
Norman -- The rule for counting states is
Number of states =(2*j1+1)(2*j2+1)(2*j3+1)...
when combining angular momentum j1, j2, j3, ...
Again, any particular j1z sate can be combined with all j2 states, and in turn with j3 states, and so forth. Two coins provide four states, a pair of dice (spin 5/2)provides 36 states. In QM, the number of states must be independent of the representation used -- so before and after must be the same. This is an enormously important concept -- a great deal of physics rests upon it(as in the Standard Theory). Most any book on QM, or angular momentum, or on the rotation group will discuss the point.
Just adding the collective number of individual angular momentum states won't cut it.
Regards,
Reilly Atkinson
Right. You can't compare the number of single-particle states to the number of states after addition. If you let |MJ1,MJ2> represent the state in which the spin-1 particle has magnetic quantum number MJ1 and the spin-1/2 particle has magnetic quantum number MJ2, then you have six of those states. That is what you compare with the six final states.
The spin space of the two particles is the direct product of their respective spin spaces. SO the dimension of space of both is the product of the dimensions, as Reilly said.
  • · Replies 19 ·
  • · Replies 18 ·
