New Reply
Transistor as a switch
Share Thread
May2-09, 06:12 PM   #1
After doing some research, I am still confused is a transistor a switch or an amplifier. If it can be used as a switch how do I find the part that will work with the gate voltage that I give it. mouser.com wasn't really helping me in finding the right part.
PhysOrg.com engineering news on PhysOrg.com
>> Mathematical algorithms cut train delays
>> Researchers design software to detect changes in colour vision
>> Trend study identifies potential for humans and technology to interact in a manufacturing environment
May2-09, 07:26 PM   #2
What voltage do you want to switch, and what current? Would an NPN open collector work?
May2-09, 07:29 PM   #3
Recognitions:
Not quite sure what you are asking.
A transistor can be used as a switch, but it can't be substituted for a switch in any position in a circuit.
It has to have its own voltage requirements satisfied.
What it means is that a transistor, as well as being an amplifier, can be turned off so it doesn't carry any current ....... or turned on so it carries as much current as a series resistor will allow.
Picture a transistor with its emitter earthed, its collector connected to a resistor which goes to a voltage supply.
If it has no base current. it will be drawing no collector current so there will be no voltage drop across the resistor so its collector will be at the same voltage as the supply.
If if has enough base current to make the voltage on the collector about half of the supply voltage it will work as an amplifier as long as you only vary the input by a small amount.
If it has a lot of base current, it will draw as much current as the series ("load") resistor will allow. It is then said to be saturated. The resistor will then have nearly all of the supply voltage across it and the transistor will have only a very small voltage across it.
If you fed a large square wave into this transistor, you could turn a relay (instead of the resistor ) on and off just like a switch could. The square wave itself may not have had enough power to do this by itself so that is why you use a transistor to do the switching.
So, "switching" mainly refers to this non linear mode where the transistor is overdriven to alternate between fully off and fully conducting.
May2-09, 07:33 PM   #4
Recognitions:
Gold Membership Gold Member
Bipolar transistors have five distinct regions of operation, defined mostly by applied bias:
* Forward-active (or simply, active): The emitter–base junction is forward biased and the base–collector junction is reverse biased. Most bipolar transistors are designed to afford the greatest common-emitter current gain, βF, in forward-active mode. If this is the case, the collector–emitter current is approximately proportional to the base current, but many times larger, for small base current variations.
* Reverse-active (or inverse-active or inverted): By reversing the biasing conditions of the forward-active region, a bipolar transistor goes into reverse-active mode. In this mode, the emitter and collector regions switch roles. Because most BJTs are designed to maximize current gain in forward-active mode, the βF in inverted mode is several (2–3 for the ordinary germanium transistor) times smaller. This transistor mode is seldom used, usually being considered only for failsafe conditions and some types of bipolar logic. The reverse bias breakdown voltage to the base may be an order of magnitude lower in this region.
* Saturation: With both junctions forward-biased, a BJT is in saturation mode and facilitates high current conduction from the emitter to the collector. This mode corresponds to a logical "on", or a closed switch.
* Cutoff: In cutoff, biasing conditions opposite of saturation (both junctions reverse biased) are present. There is very little current flow, which corresponds to a logical "off", or an open switch.
* Avalanche breakdown region
http://en.wikipedia.org/wiki/Bipolar...s_of_operation
May4-09, 12:01 PM   #5
Quote by vk6kro View Post
so I understand what you are talking about, so how would I find a transistor for my purpose. Where my circuit has an output of 3 volts. I need those 3 volts to go to base and then the collector and emitter "open and close" when it receives the 3 volts or doesn't.
May4-09, 04:46 PM   #6
Quote by noagname View Post
Any general purpose transistor like the PN2222
May4-09, 05:58 PM   #7
really? even though my emitter and collector will be a completely different voltage
May4-09, 06:31 PM   #8
Recognitions:
When the transistor (NPN) is in saturation, there is a voltage between the emitter and collector. It's typically 0.05 to 0.2 volts. See the second schematic of these trasistor switches.
May12-09, 11:16 AM   #9
How do I get it in saturation with a 2.7v(not 3v, circuit changed) going to base or am I completely off
May12-09, 11:48 AM   #10
2.7 volts is more than enough to switch a bipolar transistor. 0.8 volts is enough. If you use a differential pair or a comparator, it requires much less. Why don't you post a circuit diagram of your driving circuit, and what voltage you want to switch. Is the voltage you want to switch ground referenced, or VCC referenced?
May12-09, 08:49 PM   #11
Recognitions:
If you are using low voltages like 2.7 volts, you could choose a transistor with a high Hfe, like 400 or more. Something like a BC548 or 2N3904.
Hfe figures are available on the data sheet for the type of transistor. This is a gain figure for the transistor and tells you how much greater the collector current is than the base current.
Using this gain figure of 400 and a supply of 2.7 volts and a 1k load resistor. you would need to put a 330K resistor, in series with the base, from the previous stage.
You could use a smaller resistor, but there is usually some voltage from the previous stage, even when there is supposed to be none, and this could be enough to turn the transistor on if the resistor was smaller.
May13-09, 03:21 PM   #12
You should run the switch transistor into saturation. See Digoff's common emitter configuration. Decide whether you want a pull-up or a pull-down switch, then use a NPN or PNP configuration.
May15-09, 04:48 AM   #13
Quote by dlgoff View Post
now I am starting to get a little confused. Looking at the second schematic, in my circuit I don't have the same source going to base and collector, also their is no load between the collector and emitter. I need it to act like a light switch. and what does the 1k resistor do?
May15-09, 05:30 AM   #14
Transistor can be used as a current control switch, when you apply current (IB) to pin B, then it will allow hfe * IB to flow from C to E.
In the circuit, the 1k resistor is used to control the IB (10V-0.6V)/1K
Normally I will refer to datasheet for the hfe value (normally it's very wide), and use higher IB (higher IB will burn a little bit more energy, but you have to check your control pin's max output current and don't set the IB higher than that) so that the transistor can allow my desired amount of current to flow through even I picked a low tolerance hfe transistor.
When select the transistor for switch purpose, I think you have to look at its IC, VCE max first.
May15-09, 07:50 PM   #15
Recognitions:
Sounds like you have a project in mind.
Maybe you could draw it on paper and include the place you want to have a switch and maybe someone can help with a solution. Take a digital photo of it and then reduce it to 300 K or so and attach it to a post.
Transistors are not the only devices that can act as switches.
We may have jumped ahead a little with the explanations.
You need to think about it.
What would happen if you had two resistors in series then made one of them very small? What would that do to the voltage at the junction of the resistors?
Now make that resistor very big. What happens then?
A transistor is just like the changing resistor and it changes just because its base current is changing.
It doesn't care where the base current comes from. If there is a source of voltage and a resistance to limit the current, it will change its resistance according to the base current.
May16-09, 10:20 AM   #16
A transistor can be defined as the following:
"a 3-terminal semiconductor device useful for amplification and/or switching".
This is my own definition, which I believe is comprehensive. Note the "and/or" statement. When used as a switch, a transistor can also ampplify simultaneously. If I use a microprocessor whose i/o pins can supply 3.3V & 2.0 mA, but I need to drive a buzzer which requires 12V & 100 mA, I need some type of booster device, bjt or MOSFET.
Using either device as a switch provides current gain & voltage gain as well. The 3.3V output of the micro is insufficient to drive a 12V buzzer, & likewise for the 2.0 mA output current capability. But the transistor buffer & its associated power supply provide a boosted current and voltage so that the buzzer can be turned on & off, i.e. acting as a switch, while providing both current gain and voltage gain.
Does this help?
Claude
May16-09, 01:32 PM   #17
I suggest you use an NPN transistor in a common emmiter configuration (emitter grounded), and pull down the neg input to buzzer with the NPN open collector. Radio shack has a TIP31 or TIP3055 that probably have more than enough gain with a 100 ma collector current. Their TIP120 is a Darlington that has much more gain, and 3 volts on the base should be enough to turn it on.
Depending on whether your microprocessor 2 ma output is better at current sourcing or current sinking, you might want a resistor pullup to your Vcc.
New Reply
Similar discussions for: Transistor as a switch
Thread Forum Replies
about Using transistor BJT as a switch Electrical Engineering 9
Transistor As Switch Introductory Physics Homework 5
Using transistor to switch leds on/off Electrical Engineering 3
transistor as a switch Electrical Engineering 1
BJT transistor as a switch Electrical Engineering 21
