| Thread Closed |
Packed Absorption Tower |
Share Thread | Thread Tools |
| May4-09, 02:25 AM | #1 |
Struggling to solve this problem below. Any insight or direction would be greatly appreciated.
Effluent air stream contains 5.4% SO2 by volume. It's desired to reduce this concentration to 1000 ppm by passing the gas stream through a packed tower (counter flow absorber). Inlet gas flow rate is 1000 ft^3/min measured at 1 atm and 68 degrees F. The equilibrium of SO2 in water is represented by y = 30x. What is the approximate minimum amount of water required as a solvent in ft^3/min? |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Packed Absorption Tower
| Packed tower problem (gas-liquid absorption) | Materials & Chemical Engineering | 6 | ||
| Neutron packed together | High Energy, Nuclear, Particle Physics | 5 | ||
| Why is the mass absorption coefficient used rather than the linear absorption? | Advanced Physics Homework | 1 | ||
| Help with an absorption drying tower | Materials & Chemical Engineering | 0 | ||
| Packed column | Materials & Chemical Engineering | 2 | ||
