| Thread Closed |
maximal ideals |
Share Thread | Thread Tools |
| May6-09, 04:10 AM | #1 |
maximal ideals
Show that in a PID, every ideal is contained in a maximal ideal. Hint: Use the Ascending Chain Condition for Ideals 2. Relevant equations Every ideal in a PID is a principal ideal domain. If p is an irreducible element of a PID, then <p> is a maximal ideal. 3. The attempt at a solution Let D be a PID and let N = <a> be an ideal. I assumed that N does not equal D, since no maximal ideal of D can contain D. It follows that a is not a unit in D. If a=0 and D contains no nonzero nonunit element, then D is a field and <a>=<0> is a maximal ideal. If a=0 and D contains a nonzero nonunit b, then b has an irreducible factor p. So N=<a>=<0> is contained in <p>, which is maximal. If a is a nonzero nonunit which is itself irreducible, then <a> is a maximal ideal of D. If a is a nonzero nonunit which is reducible, then a=cq where c is a nonunit and q is irreducible. It follows that N=<a> is contained in <q>, which is maximal. This seems right to me. I'm writing this up because I never used the Ascending Chain Condition. |
| May6-09, 09:28 AM | #2 |
Twice you used the fact that a nonzero nonunit has an irreducible factor. This fact is often proved using ACC.
You might want to double check that your textbook's proof of "nonzero nonunit has an irreducible factor" didn't use as one of its steps "every ideal is contained in a maximal ideal" and leave the proof as an exercise. :) |
| Thread Closed |
| Thread Tools | |
Similar Threads for: maximal ideals
| ideals of direct product of rings are direct product of respective ideals? | Linear & Abstract Algebra | 2 | ||
| rings, ideals, prime and maximal... | Calculus & Beyond Homework | 7 | ||
| maximal optical diffusion | General Physics | 0 | ||
| need help for a maximal ideal quesiton | General Math | 6 | ||
| What do you call a maximal orthonormal set? | General Math | 3 | ||
