| Thread Closed |
Interference Wedge Problem - Analytical Chemistry&Instrumental Analysis |
Share Thread | Thread Tools |
| May6-09, 11:00 AM | #1 |
A 10.00 cm interference wedge is to be build from a dielectric layer n=1.34 and glass plate covers which have a linear dispersion from 400 to 700 nm. a) 1st-order-interference wedge How would be its construction?Indicate its thickness at the two ends of the wedge b) What would be the position of the wedge on the way of the incident beam for isolation of band at 600.0 nm (order=1) c) At what distance of wedges higher order of lines in the given range of wavelength will be observed? 2. Relevant equations m(lamda)=2t/cos(teta) (m=order) (lamda)'=lamda/n (n=refractive index) m(lamda)=2dn 3. The attempt at a solution For the first part of the solution I put the variables into the last equation and found the thicknesses as 149.25nm and 261.19nm at the ends of the wedge but I'm not sure about my answer also I could not find a way to solve the other parts.. Thanks for your help! |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Interference Wedge Problem - Analytical Chemistry&Instrumental Analysis
| Analytical Chemistry | Academic Guidance | 3 | ||
| Analytical chemistry Problem | Biology, Chemistry & Other Homework | 2 | ||
| Analytical Chemistry, Introductory | Academic Guidance | 3 | ||
| Physical Optics : Air Wedge - Interference | Introductory Physics Homework | 6 | ||
| Is instrumental analysis the worst chemistry class? | Chemistry | 12 | ||
