Why Do Wheels Make Moving Easier?
  • Context: Undergrad
  • Thread starter Thread starter lu6cifer
    Wheels Work
The discussion centers around the mechanics of how wheels facilitate movement, particularly focusing on the role of friction in comparison to sliding objects. Participants explore the physics behind rolling versus sliding friction and the implications for force required to move objects.
  • One participant suggests that the ease of movement with wheels relates to the difference in friction between wheels and sliding objects, prompting a need for proof using physics laws.
  • Another participant explains that rolling wheels, especially those with ball bearings, experience no sliding friction, contrasting this with wheels lacking bearings which do experience sliding friction but with limited contact area.
  • A further contribution notes that at the contact point of a wheel and the ground, there is no relative movement, indicating no kinetic friction. However, real-world factors like rolling resistance in tires lead to energy loss.
  • Another participant discusses the mechanics of wheels on shafts without bearings, highlighting the reduced linear force at the wheel's perimeter compared to friction torque at the axle, and introduces the idea of using cylinders or foam beads as alternatives to wheels for easier movement.
Participants express various viewpoints on the mechanics of wheels and friction, with no consensus reached on a definitive explanation or model. Multiple competing ideas about the role of friction and alternatives to wheels are presented.
Some assumptions about the ideal conditions for wheels and the effects of different surfaces and materials are not fully explored. The discussion also touches on the limitations of real-world applications, such as energy loss due to rolling resistance.
lu6cifer
I know that moving things is a lot easier with wheels, and I suspect it has something to do with the friction on the wheels versus the friction on just a regular sliding object.
But how do you prove, with the laws and equations of physics, that it takes less force to move something when there are wheels involved?
As you say, it isn't about the wheels per se, it is about what the wheels do to the friction. A rolling wheel supported by ball bearings has no sliding friction anywhere. If you have a wheel on a shaft with no bearings (ie, like a hot wheels or pinewood derby car), you will have sliding friction, but with a limited contact area and typically with a lubricant. I guess you could compare that with having a chunk of wood or metal sliding down a wood or metal ramp that is covered in oil.
Look closely at a wheel rolling across the ground. You'll notice that at the point of contact, where a wheel meets the ground, there is no relative movement. That means there is no kinetic (sliding) friction at all.
If wheels were perfect, rolling them down the road would cost no energy at all! Once you get them moving, they'd roll forever. Of course, in the real world, there are a number of ways energy is lost. For example, in an automobile, some energy is lost as the tires continually deform as they rotate. This loss is called "rolling resistance."
- Warren
Also the radius of the axle is much smaller than the outer radius of the wheel, reducing the linear force at the perimeter of the wheel versus the friction torque at the axle.
An alternative to a wheel would be a series of cylinders to allow the object to move along over the rolling cylinders. In some warehouses, the floor is covered with foam beads to make moving boxes very easy. These deform under the weight of someone walking on them (which eliminates the walking hazard), but don't significantly deform under the low pressure from the boxes and they act as ball bearings.
  • · Replies 22 ·
  • · Replies 60 ·
  • · Replies 35 ·
  • · Replies 20 ·
