Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
Go Back   Physics Forums > Physics > Classical Physics
Reply
image Share It Thread Tools Search this Thread image
Old Jul14-04, 01:33 AM                  #17
eJavier
eJavier is Offline:
Originally Posted by krab
didn't read the other thread, did you?
Not so. So you have an isolated neutron. It has a dipole moment. So what are the circulating charges that result in the tiny current loop? Other elementary particles?
I don't want to get into baryons and the internal structure of neutrons because that's off topic.
All I'm saying is this: the force on a magnetc dipole is derived from the Loretz force law, which means that the magnetic force does not work.
The point I'm trying to make is that Lorentz force law implies no work done by the magnetic force. Reading your posts I get the impression that you're saying that it's only valid for electric charges (ie. Lorentz force law), so I would like you to show me a formula for a force between an electric field and something other than an electric current. I'm honestly asking you, I'm not being a smart-***.
Best regards, Javier
Old Jul14-04, 05:07 PM       Last edited by krab; Jul14-04 at 06:17 PM.. Reason: break it up to make it more readable            #18
krab
krab's Avatar
krab is Offline:
Recognitions:
All I'm saying is that's just wrong. If you have say a uniform field LaTeX Code: \\vec{B} and a magnet with dipole moment LaTeX Code: \\vec{m} , you have to do work to pull it out of alignment with B. The torque to do this is
LaTeX Code: \\vec{N}=\\vec{m}\\times\\vec{B} .
There is a potential energy U:
LaTeX Code: U=-\\vec{m}\\cdot\\vec{B} .
Rotating the dipole out of alignment increases the potential energy. Let it go and it will rotate on its own as the potential energy decreases and the rotational kinetic energy increases. This is known as doing work. The magnetic field is doing work on the dipole, just as gravity does work on a mass that is falling. These formulas are directly from Jackson. Lorentz force is not relevant here. You are mis-applying something else, namely that a magnetic field does no work on a charged particle.
Did you mean magnetic field?
Anyway, the force law between two magnetic poles p_1 and p_2 in free space is this
LaTeX Code: F={p_1p_2\\over r^2}
in the direction of the vector r from p_1 to p_2. This can be described as p_2 in the magnetic field
LaTeX Code: H=p_1/r^2
of p_1. Equally well, describe it by a potential
LaTeX Code: \\Phi_M=p_1/r .
So you complain that monopoles don't exist. Fine. They only come in pairs. The potential from an isolated dipole is found be adding the two together:
LaTeX Code: \\Phi_M=p_1/r_1-p_1/r_2=p_1\\delta\\cos\\theta/r^2 ,
where LaTeX Code: \\delta is the separation of the two opposite poles LaTeX Code: \\vec{\\delta}=\\vec{r_2}-\\vec{r_1} , and LaTeX Code: \\theta is the angle it makes with the observation point. We call LaTeX Code: p_1\\delta the dipole moment m. So
LaTeX Code: \\Phi_M=m\\cos\\theta/r^2=\\vec{m}\\cdot\\vec{r}/r^3 .
This is the same as the formula given by Jackson.
If you have a cylindrical permanent magnet, with magnetization LaTeX Code: \\vec{M} , then it acts to a very good approximation as if it has magnetic monopoles on its North surface with a charge density LaTeX Code: \\sigma_M=|\\vec{M}| , with a surface charge density of exactly opposite sign at the South pole (this is directly from Jackson...). Get two such magnets together and they attract or repel eachother with forces given by applying the formula for F that I gave above to these surfaces and integrating. These forces have potentials and everything, just as in gravity and electrostatics.
Here's a quote from my first post "Hold two magnets apart; now they have potential energy. Let them go; now the field does work on the magnets and the result is that they accelerate towards one another." Sheesh. I'm repeating myself...
Old Jul15-04, 12:00 AM                  #19
eJavier
eJavier is Offline:
Thank you for your input krab, I'm still not convinced, but I'll go through your argument with more detail later nonetheless.
Old Jul17-04, 10:30 AM                  #20
rayjohn01
rayjohn01 is Offline:
to anybody
So when a magnet picks up iron filings off a table -- we know work is being done -- but by what?
Note that the end field is different from the start field as more filings will not be picked up. Any explanations Ray.
Old Jul23-04, 03:48 AM                  #21
eJavier
eJavier is Offline:
Hi
I have no problem with the above, except that as far as I know LaTeX Code: \\vec{N}=\\vec{m}\\times\\vec{B} comes from the Biot-Savart Law as shown by Jackson's book on page 150.
Furthermore, a magnetic moment is defined for a current distribution J (Jackson p.146)
What causes me trouble is that I'm utterly convinced that the magnetic field can't do work on the current density J that provides the magnetic moment m.
I think that your point is that magnetic poles aren't formed exclusively by charged particles and/or currents. And in the case when neither charges nor currents are involved, then work is done. Am i getting somewhere?
Old Jul23-04, 09:20 PM                  #22
esolutions99
esolutions99 is Offline:
well at the risk of sounding nieve(sp?) yall seem to be looking at this from a skewerd perspective..hehe
magnetic fields act more like kinetic(perm magnetics) energy patterns ...there is an attraction between particles...much like a difference in potential(electrical) ... the electrons flow because of the difference of potential.. similar to mag. fields ..depending on the magintude of the difference charge the objects are there fore attracted to each other
as far as work goes ..its inapproiate to use fluid equations for solid matter... im under the impression that work equations dont work well here....is there work done when electricity flows through a circuit? electrons flow because of thier diff in potential its part of thier physics..is attracting iron filings work ?....as much as electron flow (or hole flow) its just what they do dudes
Old Jul24-04, 10:25 PM                  #23
rayjohn01
Maybe the misconception ( original) was that a magnetic field does no work on a charged particle applies to a STATIC particle , not one in general.
Old Jul24-04, 10:41 PM                  #24
eJavier
eJavier is Offline:
Magnetic field don't work on any charged particle. This follows from the Lorentz force Law. If you want a proof just ask :D.
Old Jul25-04, 07:35 AM                  #25
rayjohn01
hence
To eJ
Therefore electric motors cannot work , or dynamos ???????????
Old Aug4-04, 12:43 PM                  #26
eJavier
eJavier is Offline:
to krab:
I finally found out what's the problem. The formulas you wrote for the energy and work are mechanical work. You still need to add the energy of the electric currents. If you do that then you'll get zero work. This is in one of Feynman's lectures, chapter 13 I think.
I'm kind of busy now but as soon as I get some spare time I'll post here the most important of the aforementioned lecture.
to rayjohn:
A dynamo does not work in the sense that it can't speed up an electron. what it does is this: it takes the work done by the waterfall or wathever and converts it into electric work. So really the one doing the work is the one moving the dynamo.
Old Aug4-04, 04:22 PM       Last edited by rayjohn01; Aug4-04 at 04:37 PM..            #27
rayjohn01
mag work.
To Ejavier
I do not understand your answer, dynamos are quite capable of moving electrons since they generate current , it's clear where the original energy came from, and it's clear that in an ideal set up the field is not dissipating energy in the form of heat but it is transmitting energy and doing so by accellerating electrons.
So I'm not really sure what you mean by not doing work, do you mean producing work as an energy source -- I would agree with that.
But if I compared to a lever lifting a weight ( a transmitter of work) would I not say that the lever is doing work ( but not producing it).
Maybe it's just semantics or there is a different definition being used, but there is no question that magnetic fields accellerate electrons without that effect we'd all fry from the sun's radiation.
Also I believe that a magnetic field can be a source of energy , if you take the case of two bar magnets attracting each other they accellerate collide and dissipate heat and sound. The energy comes from the partial collapse or reorientation of the fields.
In that case the system can be recharged by pulling them apart , but to me that's rather like recharging a battery and were quite happy saying that a battery can do work .
Old Aug4-04, 10:06 PM       Last edited by eJavier; Aug4-04 at 10:11 PM..            #28
eJavier
eJavier is Offline:
I said that a magnetic field can't SPEED UP electrons and I stand by that. It can deflect them of course.
The fact is that the force that a magnetic field exerts on an electron is always perpendicular to the trajectory (same as a satellite in a circular trajectory in a central force field) so it doesn't work.
In the example you wrote about the bar magnets, there is of course a mechanical work done, but you have to take into account the work done to sustain the currents. It's all explained in the second volume of Feynman's lectures, chapter 13 I think.
Old Aug5-04, 03:23 AM                  #29
hi_rudra
hi_rudra is Offline:
the field certainly doesnot do anywork.all that happnes is it lifts the iron(or even U may thought of attraction between two magnet),perpendicular to the line of force so that F=vxB is still vaid.In some cases induction also take place and by 3rd law of Maxwell,it is electric field which does the work
Old Aug5-04, 09:05 AM       Last edited by rayjohn01; Aug5-04 at 09:09 AM..            #30
rayjohn01
So then a 'relay' operates via an 'electric' field --- right -- and no work is done in closing it's contacts -- according to this we can do without inductors entirely, and you know you can ( in theory by using an active device -- see switched capacitor filters the phase shift required is 180 dgrees ).
An inductor is the perfect model -- it can have a permanent field and a dynamic one.
It's equivalent circuit is that of pure inductance which is an energy storage device.
It is the stored energy which can do work and if it does the energy must be replenished.
EJaviers example of a rotating vector is like a hammer hitting nothing , but we use the hammer to drive the nail , and we don't say 'my fist did it ' even tho' thats where the energy came from.
Dynamic magnetic fields can speed up electrons which is why the suns storms exist especially due to field collapse.
However if you wish to remove magnetics by talking of charge spin fine .
So according to you electromagnetic energy ( radiowaves ) is only carried by the electric field -- tell Maxwell -- the energy is contained equally in both and the waves can do work if not -- then what the heck have I been listening to all this time on my radio ??????????
Old Aug5-04, 11:15 PM                  #31
eJavier
eJavier is Offline:
Magnetic fields ain't like a hammer hitting a nail since the hammer does work.
Magnetic fields are like the normal force on a ramp. It doesn't do any work since it's perpendicular to the displacement.
Old Aug6-04, 11:13 AM                  #32
rayjohn01
time is important.
to EJavier.
Then please explain radiation where both fields are normal to displacement but obviously do work (equally) per the photon. They do work BUT dissappear because the stored energy is used . A purely static and unchanging field does no work , a changing field gives or accepts energy,- like a spring, an accellerating field gives rise to radiation , all of which you could equally say about the electrostatic field.
In a tuned circuit comprising a capacitor and an inductor which is oscillating energy is continually exchanged from one to the other in both potential and kinetic forms -- the introduction of a resistance causes an exponential decrease in oscillation as energy is used -- both fields decrease as work is done producing heat. The cap' and ind' voltages are both normal to the current( in the sinusoidal sense) so they produce no internal heat but they have changing energy, represented by the resistance heat.
But I agree that that is a non-conservative system in that heat is a random motion.
However the photon does not have to produce heat it could release (say) electrons from a metal surface exchanging energy to kinetic of the electron.
The normal force on a ramp does work -- it compresses the object which is stored energy - which can be released if the object falls off the ramp.
image image
Reply
Thread Tools
Similar Threads for: work done by magnetic field
Thread Thread Starter Forum Replies Last Post
Does magnetic field do any work.. AlbertEinstein Classical Physics 44 Jun25-08 01:26 AM
Magnetic Field and Work Phrak Classical Physics 7 Apr5-08 11:36 PM
the magnetic field and work Tony11235 General Physics 5 Dec5-05 01:41 PM
Magnetic Field and Work leolaw Introductory Physics 8 Mar19-05 04:24 PM
Work done by magnetic field... sridhar_n Classical Physics 17 Jun21-04 05:00 AM
Powered by vBulletin Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
