Calculating Net Force on Positive Particles Using Coulomb's Law and Vectors
The discussion revolves around calculating the net force on three positive particles arranged at the corners of an equilateral triangle, using Coulomb's Law and vector analysis. The charges are specified, and the geometry of the setup is described, including the length of the sides of the triangle.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants express difficulty in understanding the concepts of Coulombic force, vector summation, and the geometric arrangement of the charges. Questions are raised about how to calculate the forces acting on the particles and how to find the resultant force from multiple interactions.
Some participants are seeking clarification on the fundamental concepts involved, while others are attempting to guide the discussion towards understanding the forces acting on individual charges. There is an ongoing exploration of how to approach the problem without reaching a consensus on the method or solution.
Participants are working within the constraints of a homework problem, which may limit the information available and the assumptions that can be made about the system. The specific arrangement of the charges and their magnitudes are critical to the discussion.
supermenscher
Can anyone help me with this one, its really giving me problems. u = 10^-6C
Three positive particles of charges 12.5uC at the corners of an equilateral triangle. The sides of the triangle are 0.17meters long. Calculate the magnitude and direction of the net force on each particle. Of the 3 positive particles, Q1 is at the top of the triangle, Q2 is the left side of the triangle, and Q3 is the right side of the triangle. Please help!
What is it about the problem that gives you trouble? The concept of Coulombic force? Vector summation? Geometry?
Basically the whole thing...I just can't get the grasp on how to do it. Could you please help me? Thanks
If you had just 2 charged particles, how would you find the force that acts upon one of them from the other, that is: what is the Coulomb force acting on a charged particle from another charged particle?
could some one explain this a little further, that would really help me. thanks
Consider Q1. It experiences forces from Q2 and Q3. Each of these forces may be calculated using Coulomb's Law - in fact, they have the same magnitude. The directions of these forces are found by extending the lines Q2Q1 and Q3Q1 and sticking little arrowheads on their ends, pointing away from Q2 and Q3. OR, Q2 and Q3 try to push Q1 away from them. Now you need to find the resultant force. You can do this by resolving each of the two forces into vertical and horizontal components. In this case, the horizontal components are equal, but in opposite direction, so they cancel each other. So you are left with twice the vertical component of one force.
39K
11K
