Funnel vs Cylinder: Find Out Which Is More Efficient for Pouring Water
  • Thread starter Thread starter Melawrghk
    Cylinder
The discussion revolves around the efficiency of using a funnel compared to a cylinder for pouring water. Participants explore the reasons behind the preference for funnels in practical scenarios, particularly when both have the same exit radius.
  • Participants discuss the physical characteristics of funnels and cylinders, questioning the impact of shape on pouring efficiency. Some suggest that funnels prevent spillage and require less precision, while others consider the effects of pressure and volume loss in different shapes.
The conversation is ongoing, with participants sharing insights and raising questions about the underlying principles of fluid dynamics. Some guidance has been offered regarding practical considerations, but no consensus has been reached on the primary reasons for the efficiency of funnels over cylinders.
One participant mentions a project requirement to justify the use of a funnel, indicating that there may be specific criteria or constraints influencing the discussion.
Melawrghk
Pretend you have a container into which you're pouring water. We often use funnels, but why? Like if you have a funnel with the same exit radius as a cylinder, why is using a funnel more efficient?
The area still says the same, so I don't know. Help?
Maybe because a funnel won't fall into the recipient you are filling while a cylinder would!
I could glue the cylinder onto the recipient :D
Could it be because pressure changes differently between the two shapes? Cylinder loses the volume of water and height of water linearly. But a even if a cone loses same amount of water by volume, it would be different by height?
This is right. But why would pressure be a problem? If it is a problem then it explains it all, but if you use it for cooking or things like that I think it's because the funnel simply don't fall into the recipient and also because you don't have to be very precise (accurate) when you pour the water into the funnel since it's almost sure all the water will get on the funnel and not on the floor. While when pouring water in a thin cylinder requires more accuracy from your part and you can't also pour water with it as fast as with a same volume funnel.
Well it's for my project, and I'm supposed to justify use of cone as opposed to having just an open (cylindrical) end. I think I'll be able to develop an argument from this. Thanks tons!
Ok good luck then! I'm hoping for someone to point out any other information we might be missing.
  • · Replies 67 ·
  • · Replies 40 ·
  • · Replies 25 ·
