A question regarding Potential Energy
The discussion revolves around the concept of potential energy, particularly in the context of gravitational potential energy and the implications of the Earth's gravitational field. Participants explore hypothetical scenarios where the Earth disappears or loses mass, questioning how this affects the potential energy of an object and the conservation of energy principle.
  • Some participants assert that potential energy is dependent on the presence of a gravitational field, specifically that of the Earth.
  • One participant questions whether a weight would lose its potential energy if the Earth were to disappear, suggesting that potential energy exists only due to Earth's gravity.
  • Another participant states that if the Earth were to vanish suddenly, it would violate conservation of energy and mass.
  • Some argue that if the Earth were to move away slowly, the conservation of energy could still hold, as energy would need to be given to the Earth to facilitate this movement.
  • There is a discussion about the mutual potential energy between the Earth and the object, suggesting that potential energy is not solely one-sided.
Participants express differing views on the implications of the Earth's disappearance on potential energy and conservation laws. There is no consensus on how these scenarios would satisfy the conservation of energy principle.
Participants highlight the dependence of potential energy on gravitational fields and the complexities involved in hypothetical scenarios that challenge conservation laws. The discussion includes assumptions about the nature of energy and mass in these scenarios.
brum
Let's say I lift a 50 pound weight with my arms to shoulder height (say, 4 feet). The "work" that I did to get the weight up there (the energy I put in) has now been converted to "potential energy" because it is perched in a position where it can then convert that into kinetic energy.
But, that potential energy is there only because of the Earth's gravity, right? If I were to let go of the weight, it would convert the energy I put into lift it (potential energy) into kinetic energy -- falling towards Earth.
In other words, that potential energy exists only because of Earth's gravity.
Suppose I were to lift the weight 4 feet in the air, and then Earth disappeared or vanished or lost a lot of mass or whatever. Just say the Earth went away. Wouldn't the weight then lose its potential energy (because the Earth is no longer there)?
EDIT: How would this situation satisfy the Conservation of Energy rule?
If the Earth just "disappeared", you wouldn't conserve energy, or mass.
JMD
Yes.
It wouldn't (unless the Earth "dissapeared" at less than
the speed of light :wink:).
Live long and prosper.
The concept of potential energy depends upon a potential, which is nothing more than a way to express a field. Without a gravitational field, there is no such thing as gravitational potential energy.
- Warren
In lifting the weight you have to move it obviously. Think of the force being constant and the velovity you lift it with constant as well. As soon as you let go the energy will be constant since you're no longer doing work on the system. The weight has kinetic energy since it was moving and it has a potential energy since you stopped applying the force at a non-zero height above the ground. The quantity
E = "Kinetic Energy (T)" + "Potential Energy (U)"
is constant. I.e.
E = T + U = constant
The force F can be written in terms of the potential energy U as
F = -grad U
where "grad" is the gradient operator. In one dimension, say "z", that becomes (for one a potential with one variable)
F = -dU/dz
The gravitational field sometimes defined in terms of a "gravitational potential," Phi, defined as Potential Energy per unit mass. I.e.
Phi = U/m
So you're right. No gravitatiolnal fieldno potential energy.
If the Earth's gravitational field just turned off then it would violate the principle of the conservation of energy since there is energy associated with the gravitational field itself.
Hope that helps
Pete
Brum, you have conclusively proved that, due to the conservation of mass and energy, the Earth cannot simply disappear!
Whew, that's a relief!
If it went away suddenly, and disappeared, it will be against the rules of conservation of mass and energy, but let's suppose the Earth went away slowly (less than c), and for some reason you didn't stay on it.
In this case, this (moving the Earth away from you) will need energy to be given to the Earth to move away from you, and this will be a potential energy in the Earth to you (well, and you will also have potential energy towards earth), so the law of conservation of energy will still be valid.
There's little cause to say that the Earth is moving and not you. So what is the cause/reason that you don't move with it? There is work being done on you giving you energy
Pete
Well, you cannot know if actually the energy is yours or the earth's.
You see, when you have potential energy to earth, Earth has potential energy to you too.
In my example, it could be that you are connected to the sun for example :smile:
  • · Replies 29 ·
  • · Replies 21 ·
  • · Replies 54 ·
