Register to reply
Finding the electric field magnitude, and angle below the horizontal
Share this thread:
jheld
#1
May8-09, 05:20 PM
P: 81
In the figure below d = 2.6 cm. What is the electric field at the position indicated by the dot in the figure?
2. Relevant equations
E = charge/4*pi*epsilon_0*distance^2
The figure is on the attachment.
3. The attempt at a solution
I decided to first find only the magnitude from each of the fields on the point.
charge 1 = 10 nC;
charge 2 = 5 nC;
charge 3 = -5nC
*I put all of the charges into Coulomb before any calculations
E1 = Kc1/5d^2;
E2 = Kc2/d^2;
E3 = kc3/4d^2;
After adding all of the Es together I get the wrong answer (as far as magnitude).
Answer is: 7.9 104 N/C, at 5.2 below the horizontal
Phys.Org News Partner Science news on Phys.org
Hoverbike drone project for air transport takes off
Earlier Stone Age artifacts found in Northern Cape of South Africa
Study reveals new characteristics of complex oxide surfaces
Doc Al
#2
May9-09, 05:45 AM
Mentor
Doc Al's Avatar
P: 41,302
Quote Quote by jheld View Post
E1 = Kc1/5d^2;
E2 = Kc2/d^2;
E3 = kc3/4d^2;
You can't just add up the magnitudes like ordinary numbers (if that's what you did). You must add them as vectors. What is the direction of each field?
Register to reply
Related Discussions
Finding the magnitude of the electric field at the midpoint between two point charges Introductory Physics Homework 22
Finding magnitude of electric field strength! Introductory Physics Homework 4
Physics question-finding the magnitude of the electric field Introductory Physics Homework 1
Finding the electric field magnitude in a parallel plate compacitor. Introductory Physics Homework 5
Finding Electric field magnitude of a wire Introductory Physics Homework 1
