Register to reply
How do Toroids work, and What are they used for?
Share this thread:
Triangulum
#1
May9-09, 12:28 PM
P: 12
How do Toroids (inductors) work, and What are they used for (in electronics and/or other physics applications)?
Thanks
Phys.Org News Partner Physics news on Phys.org
Researchers demonstrate ultra low-field nuclear magnetic resonance using Earth's magnetic field
Bubbling down: Discovery suggests surprising uses for common bubbles
New non-metallic metamaterial enables team to 'compress' and contain light
deferro
#2
May9-09, 01:19 PM
P: 49
They're used for lots of things: washers, bangles, rings on fingers; it's just a shape, like 'square' is.
Dadface
#3
May9-09, 01:35 PM
PF Gold
Dadface's Avatar
P: 2,019
Quote Quote by Triangulum View Post
Thanks
Are you thinking of toroidal magnets?
Triangulum
#4
May9-09, 02:46 PM
P: 12
Sorry for not specifying, but I meant Toroids as in the electricity and magnetism part of physics, such as an inductor or a "round solenoid."
Thanks
deferro
#5
May9-09, 08:13 PM
P: 49
A toroidal ferrite core with wire wound on it is called a choke in EE.
Try wikipedia (and an old PC power supply); do you understand induction?
Triangulum
#6
May9-09, 08:46 PM
P: 12
I understand induction, but I can't think of any real-life applications of when a toroid would be useful.
deferro
#7
May9-09, 08:55 PM
P: 49
Hmm, well, choke coils are fairly ubiquitous, see what a choke does and see if it looks useful.
mgb_phys
#8
May9-09, 09:27 PM
Sci Advisor
HW Helper
P: 8,953
An inductor blocks transmission of a fast changing signal such as external interference on a wire.
They are normally only called chokes when they are inductors in circuit.
Phrak
#9
May9-09, 09:54 PM
P: 4,512
It depends on the application, and frequency domain where the material can be powdered iron, or wound soft steel tape, or ferrite.
In small, bead form, on a wire, torroids block noise. Toroidal cores are even used in 60Hz transformers where a low profile is a requirement. Current transformers, antenna balums, and line filters are some uses. Way back when, square BH core material toroids were used to store data bits (core memory).
Packaged with a couple capacitors, or used discretely, they are commonly used as line filters.
Register to reply
Related Discussions
Magnetic flux of toroids Introductory Physics Homework 0
Solenoids and Toroids Advanced Physics Homework 12
Solenoids and Toroids Introductory Physics Homework 4
Toroids on graphics cards and some other circuits Introductory Physics Homework 4
Ampere's Law: Toroids Introductory Physics Homework 0
