Fourier transform of rectangular pulse (Waves)
The Fourier transform of a rectangular pulse, characterized by height H and total length t0, is defined by the equation F(w) = ∫ from -∞ to ∞ of f(t)e^(-iwt) dt. The amplitude density of the Fourier transform is proportional to sinc(wt0/2). The confusion regarding the integration variable arises from the need to integrate with respect to time (t) rather than frequency (w) to obtain a function of frequency.
  • Understanding of Fourier transforms and their properties
  • Familiarity with the sinc function and its applications
  • Knowledge of complex exponentials in signal processing
  • Basic calculus, particularly integration techniques
  • Study the properties of the sinc function in signal processing
  • Learn about the implications of Fourier transforms in time-frequency analysis
  • Explore normalization conventions in Fourier transform definitions
  • Investigate applications of Fourier transforms in communications and signal analysis
Students and professionals in electrical engineering, signal processing, and applied mathematics who are working with Fourier transforms and analyzing waveforms.
tigger88
F(w) is the Fourier transform of f(t). Write down the equation for F(w) in terms of f(t).
A rectangular pulse has height H and total length t0 in time. Show that as a function of w, the amplitude density is propertional to sinc(wt0/2).
F(w) = integral from -infinity to +infinity of: f(t)exp(-iwt)dw
integral from -t0/2 to +t0/2 of: h*exp(-iwt)dw
I have access to the solution to this problem, which says that it should be:
integral from -t0/2 to +t0/2 of: h*exp(-iwt)dt,
but I don't understand why I'm integrating wrt t now, when the definition says w.
Could somebody please explain this?
Thanks in advance.
Where do you get that definition from? Think about it, you want to find a function [itex]F(\omega)[/itex], but if you calculate the integral you've written down as the "definition" then the integration boundaries will be inserted into [itex]\omega[/itex] after the integration. As as a result you won't have a function with variable [itex]\omega[/itex].
The correct definition is (normalization conventions can be different):
[tex] F(\omega)}=\int_{-\infty}^\infty e^{-i \omega t} dt[/tex]
Actually I got that definition from the solution to the question. It makes a whole lot more sense now, thanks for your reply!
  • · Replies 0 ·
  • · Replies 16 ·
  • · Replies 31 ·
  • · Replies 17 ·
