HI Cloud & 21cm Line: Calculate, Ratio & Luminosity
  • Thread starter Thread starter TFM
    Cloud Hi Line
The discussion revolves around the calculation of energy level differences in hydrogen atoms leading to 21 cm line emission, as well as the relationship between the total 21 cm luminosity and the mass of HI clouds. It includes theoretical aspects and mathematical reasoning related to atomic states and luminosity calculations.
  • Homework-related
  • One participant calculated the energy difference for the 21 cm line emission as 9.43*10^{-25} Joules but struggled to show the expected ratio of hydrogen atoms in the upper to lower state.
  • Another participant pointed out that the ratio of upper to lower states should be less than 1 for any temperature, questioning how a 3:1 ratio could be achieved.
  • Some participants discussed the implications of having multiple upper and lower states due to the spins of the proton and electron, suggesting that this could lead to the observed ratio.
  • There was a clarification about the total spin states when the spins are parallel or anti-parallel, leading to a discussion on the number of states associated with different total spins.
  • One participant proposed a formula for luminosity based on the mass of the HI cloud but was unsure how to incorporate the decay rate provided in the problem statement.
  • Another participant suggested considering the luminosity of a single hydrogen atom and the average time it takes to radiate energy as a way to approach the second part of the problem.
Participants generally agree on the calculations related to energy differences and the concept of atomic states but have not reached consensus on how to correctly derive the 3:1 ratio or the relationship between luminosity and mass. The discussion remains unresolved regarding the best approach to the second part of the problem.
There are limitations in the discussion regarding the assumptions made about atomic states and the application of formulas for luminosity, particularly in relation to the decay rate and the nature of radiation from hydrogen atoms.
TFM
Consider an HI cloud of temperature T ≥ 3 K.
a)
Calculate the energy level difference between the hydrogen atom states leading to 21cm line emission. Show that the ratio of hydrogen atoms in the upper to the lower state of the 21 cm line is approximately 3:1.
b)
Assuming the cloud to be optically thin, find a relation between the total 21 cm Luminosity (in Watts) and the mass of HI (in solar masses). The decay rate is [tex]A_{21} ≈ (1.1 × 10^7 yr)^{−1}[/tex].
I have done the first part of a), finding the Energy Difference. I got this to be
[tex]9.43*10^{-25}[/tex]Joules.
I thought the formula for the second part opf a, showing the ratio is approx. 3, required this formula:
[tex]\frac{n_2}{n_1} = exp(\frac{-(e_2 - E_1)}{kT})[/tex]
However, this doesn't give me a reasonable value, the value comes a=out to be about 1.
I am also slight uncertain about what to do on part b.
Any ideas would be most appreciated,
TFM
(a) You did the calculation correctly, but have left out a key factor.
Hint:
For any temperature, a state of higher energy will always have fewer atoms than a state of lower energy. This is because the expression
n2/n1 = e-ΔE/kT
is always less than 1, for any temperature.
How then might it be possible for the higher energy to have 3 times as many atoms as the lower energy?
Hint:
[tex]n_2/n_1 = e{-\Delta E/kT}[/tex]
It would seem to be impossible then, if for any temperature there will be always be more atoms in a lower state of energy.
If there were really just one upper state and just one lower state, that would be true.
Well, wouldn't there be two upper and lower states, since the proton/electron pair can be either parallel up or parallel down (higher energy) or anti-parallel, with either the electron up/proton down or proton up/electron down?
While that appears to be a reasonable way of thinking about it ... it's incorrect :-(
Instead, think of: what is the total spin S when both spins are parallel? How many mS values are there for this value of S?
Well, when they are parallel, the spin will be either positive or negative 1, since they will be either both plus half, or both minus half. When they are anti-parallel, the total spin will be 0, since they will always be one positive half, one negative half.
Okay, good. (Actually the parallel case is "spin = 1", since we are just talking about the magnitudes of the spin).
How many states exist for spin=1? And for spin=0? Hint: this is the m quantum number.
Looking through my noted, but all I am getting is m_s = plus/minus one half, which doesn't seem to work for this.
would it be m = 0 for s = 0, and m = -1, 0, 1 for s = 1?
Yes, that's right.
So there is three upper states, and only one lower state, would this how the 3:1 ratio?
Yes, exactly.
Excellent.
So for the next part, what is the best way to show the relationship between H21 luminoscity and the mass. So would the right thing to be to use the fomrula:
[tex]L = 4\pi r^2 \sigma T^4[/tex]
and the fact that:
[tex]v = \frac{m}{\rho}[/tex]
and for a sphere:
[tex]v = \frac{4}{3}\pi r^3[/tex]
which can be rearranged to give:
[tex]L = 4\pi \left( ^3\sqrt{\frac{3}{4\pi}\frac{m}{\rho}} \right)^2 \sigma T^4[/tex]
where it is cube root,
however, this doesn't use the decay rate that is given...?
That approach doesn't work, since the H atoms are radiating at a single wavelength, and not a blackbody spectrum.
Probably best to think first what would be the luminosity of one single H atom. Then figure out how many H atoms there are.
well the luminosity is the energy radiated over time, now we know the energy difference. Would that be useful?
Yes. And, the average time it takes to radiate that energy is useful as well.
  • · Replies 16 ·
