Logarithms where you are solving for X
  • Thread starter Thread starter chemistudent
    Logarithms
The discussion revolves around solving logarithmic equations, specifically focusing on the equation log2(x-5)=5 and its equivalent forms. Participants explore the conversion of logarithmic expressions to exponential form and the implications of these transformations.
  • Participants discuss the steps taken to solve the logarithmic equation and express uncertainty about the requirements of the problem. Questions arise regarding the use of calculators for logarithmic calculations, particularly when only log10 is available.
Some participants have provided guidance on checking solutions and clarifying the relationship between logarithmic and exponential forms. There is acknowledgment of the equivalence of different logarithmic expressions, though no consensus is reached on all aspects of the problem.
Participants express confusion about the problem's requirements and the methods for verifying their answers, particularly in relation to calculator limitations. The discussion also touches on the equivalence of different logarithmic equations and their solutions.
chemistudent
Put in Exponential form and solve for X. SHOW YOUR STEPS!
log2(x-5)=5
I am not sure what this is asking for. There are no other equations.
25=X-5
25+5=X-5+5
32+5=X
X=37
Looks good to me. What's the question?
How can I check this with a calculator? Because mine only has log10
And if there isn't a way to check this with a calculator, Is there some website or something that i can use? Because when I look I can't find one.
You should be able to take log2(32) in your head. Since 32=2^5. But for future reference, log2(x)=log10(x)/log10(2).
um. I entered it into my calculator and I got an answer of 166.7025077 instead of 5.
I entered (log(37)/log(2))(X-5)
Put x=37. log2(x-5)=log2(37-5)=log2(32)=log10(32)/log10(2)=1.50515/0.30103=5. But again, this isn't a question where you need to rely on a calculator.
ok then.
um... one more question
3(X+6)=27
log327=X+6
Aren't these the same thing?
And if they are is this how you would answer this question?
3(X+6)=27
log327=X+6
(log(27)/log(3))-6=X+6-6
3-6=X
X=-3
Yes, the two equations are equivalent, which means essentially that they are both saying the same thing. Both have the same value of x as their solution.
In the first equation, 3x + 6 = 27, x + 6 represents the exponent on 3 that gives you 27. That means that x + 6 = 3, or equivalently, that x = -3.
In the second equation, log3 27 = x + 6, the left side simplifies to 3, giving you 3 = x + 6, or equivalently, x = -3.
Every time you have an exponential equation, there is an equivalent log equation that has the same solution (as long as the base is positive and not equal to 1). The opposite is also true; namely that every log equation has an exponential equation counterpart.
  • · Replies 22 ·
