Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
Go Back   Physics Forums > Mathematics > Number Theory
Reply
image can magma do this? Share It Thread Tools Search this Thread image
Old May14-09, 09:03 AM                  #1
chhitiz
chhitiz is Offline:
can magma do this?
if x is an integer,
x1=6x2+8x+2
x2=6x21+8x1+2
x3=6x22+8x2+2
x4=6x23+8x3+2
x5=6x24+8x4+2
if i want to see x5 in terms of x, can it it done using magma?
if so can somebody please give me the code?
thanks.
Old May14-09, 02:11 PM                  #2
matt grime
Math Guru 2008
matt grime is Offline:
Recognitions:
Homework Helper Homework Helper
Re: can magma do this?
Yes. Define a poly ring, define f to be 6x^2 + 8x+2, then evaluate f(f(f(f(f(x)))))
Old May14-09, 03:33 PM                  #3
chhitiz
chhitiz is Offline:
i am totally ignorant of the code,and have absolutely no idea how to define a polyring. please, can somebody tell me the code?
Old May14-09, 03:53 PM                  #4
HallsofIvy
PF Mentor
HallsofIvy is Offline:
What, you want to solve a problem by pouring molten rock on it? How do you turn in the solution to your teacher?
Old May14-09, 05:06 PM                  #5
matt grime
Math Guru 2008
Recognitions:
If you don't know how to use magma, then why do you want to use magma? Start with the magma documentation if you want magma help.
The answer can be worked out by hand easily (if laboriously).
If you want to learn magma this seems like a strange way to go about it.
Old May14-09, 07:20 PM                  #6
squidsoft
squidsoft is Offline:
Originally Posted by chhitiz View Post
if x is an integer,
x1=6x2+8x+2
x2=6x21+8x1+2
x3=6x22+8x2+2
x4=6x23+8x3+2
x5=6x24+8x4+2
thanks.
This is Mathematica code (and output). Hopefully you can convert it to the hot stuff.
Code:
In[10]:= Expand[Nest[6*#1^2 + 8*#1 + 2 & , x, 5]]
Out[10]= 3074457345618258602 +
   147573952589676412928*x +
   3431094397709976600576*x^2 +
   51466415965649649008640*x^3 +
   559697273626439932968960*x^4 +
   4701457098462095436939264*x^5 +
   31734835414619144199340032*x^6 +
   176808368738592374824894464*x^7 +
   828789228462151756991692800*x^8 +
   3315156913848607027966771200*x^9 +
   11437291352777694246485360640*x^10 +
   34311874058333082739456081920*x^11 +
   90068669403124342191072215040*x^12 +
   207850775545671558902474342400*x^13 +
   423124793075117102051465625600*x^14 +
   761624627535210783692638126080*x^15 +
   1213839250134242186510142013440*x^16 +
   1713655411954224263308435783680*x^17 +
   2142069264942780329135544729600*x^18 +
   2367550240199915100623496806400*x^19 +
   2308361484194917223107909386240*x^20 +
   1978595557881357619806779473920*x^21 +
   1483946668411018214855084605440*x^22 +
   967791305485446661862011699200*x^23 +
   544382609335563747297381580800*x^24 +
   261303652481070598702743158784*x^25 +
   105526475040432357168415506432*x^26 +
   35175491680144119056138502144*x^27 +
   9422006700038603318608527360*x^28 +
   1949380696559711031436247040*x^29 +
   292407104483956654715437056*x^30 +
   28297461724253869811171328*x^31 +
   1326443518324400147398656*x^32
Old May24-09, 12:15 PM                  #7
chhitiz
chhitiz is Offline:
ok, i got how to declare a polyring and defined f<x> :=6*x^2+8*x+2;
but how to evaluate f(f(f(f(x))));
image image
Reply
Thread Tools
Similar Threads for: can magma do this?
Thread Thread Starter Forum Replies Last Post
Moduloid - Abelian Unital Magma Tom Piper General Math 4 Feb3-06 10:25 PM
Powered by vBulletin Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
