Thread Closed
Finding the apparent magnitude of the sun, and finding Distances from it.
Share Thread Thread Tools
May16-09, 01:20 PM   #1
TFM
During its lifetime a massive star converts about one solar mass of hydrogen into iron in its core, releasing about 0.7 percent of the rest-mass energy in the form of radiation. When it explodes as a supernovae, the outer envelope of the star (with a mass of 10Msun, say) is ejected at speeds of up to 10,000kms−1.
b)
About 1 per cent of the supernova energy is radiated in the optical over a timescale of about 1 month. Estimate the average luminosity of the supernova in units of the solar luminosity over this time.
done
c)
Using the above numbers, estimate the distance to which supernovae can be detected in an optical survey that images each field of the sky down to an apparent magnitude of mV = 18 once per month. (The absolute magnitude of the Sun is M(sunV) = 4.8.)
2. Relevant equations
[tex] F = \frac{L}{4\pi d^2} [/tex] (1)
[tex] m = m_0 - 2.5 log_{10}(F) [/tex] (2)
[tex] m = M + 5(log_{10}d - 1) [/tex] (3)
3. The attempt at a solution
Okay I have done b), which I got an answer of10.8 Solar Luminosities
However, I am now on part c). I know I need to use the magnitude equation (2) with the flux of the star (1). Now, m0 is the reference flux, which will be the suns. Now I am trying to calculate this, since they give M for the sun. however using (3), I calculate the m value to be around 50, which is much big to the answer I found on the internet, 26. I did the following:
M = 4.8, d = 1Au = 1.5 * 10^11 m
[tex] m = 4.8 + 5(log_{10}1.5*10^{11} - 1) [/tex]
[tex] m = 4.8 + 5(11 - 1) [/tex]
[tex] m = 4.8 + 5(10) [/tex]
m = 54.8
Any ideas where I have gone wrong?
Many thanks in advanced,
TFM
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Thread Closed
Thread Tools
Similar Threads for: Finding the apparent magnitude of the sun, and finding Distances from it.
Thread Forum Replies
Calculating absolute magnitude and apparent magnitude Advanced Physics Homework 1
Help with with finding the magnitude of a charge Introductory Physics Homework 2
Apparent distances as seen from within Schwarzschild solution Special & General Relativity 2
Finding Mass and Distance using apparent Weight Introductory Physics Homework 17
Finding Magnitude Introductory Physics Homework 18
