Spring mass system with applied force kinetic energy
The discussion focuses on modeling a spring mass system with an applied force using Lagrangian mechanics. The user seeks clarification on calculating kinetic energy, specifically using the formula KE = 1/2 mv² and the work-energy principle expressed as ΔKE + ΔPE = W. The conversation highlights the importance of distinguishing between impulse and work, with the user planning to extend their calculations to double spring systems with applied forces.
  • Lagrangian mechanics
  • Kinetic energy calculations
  • Work-energy principle
  • Impulse vs. work differentiation
  • Study the application of Lagrangian mechanics in complex systems
  • Explore the work-energy theorem in detail
  • Investigate double spring systems and their dynamics
  • Learn about impulse and its relation to work in physics
Physics students, mechanical engineers, and anyone interested in advanced dynamics and energy calculations in spring mass systems.
fobos3
I'm trying to work out a model for a spring mass system with a force acting at the centre of mass of the mass using Lagrangian mechanics. I can't work out the kinetic energy. I know the kinetic energy [tex]\text{KE}=\dfrac{1}{2}mv^2[/tex]. I also have [tex]W=\int_a^b F \, dt[/tex].
Should I use [tex]\Delta \text{KE} + \Delta \text{PE} =W[/tex]
Some help will be appreciated.
P.S. I'm using Lagrangian mechanics because later I'm planning some calculations on double spring systems with applied force.
W = [tex]\int[/tex] [tex]\vec{F}[/tex] [tex]\cdot[/tex] [tex]\vec{dx}[/tex]
The expression you had was for Impulse not Work
  • · Replies 77 ·
  • · Replies 24 ·
  • · Replies 17 ·
  • · Replies 16 ·
